Another 650 demo
2006-09-12 by djbrow54
Index last updated: 2026-03-31 01:40 UTC
2006-09-13 by xamboldt
On Sep 11, 2006, at 10:39 PM, djbrow54 wrote:
> Another MOTM-650 arpeggiation sequence using my HoldAllNotes program:
> 650 demo-holdallnote2.mp3
> The PSIM sends the note on's, but not the note off's to the 650
> allowing me to build up a pingpong sequence for the first 16 notes.
> All other MIDI notes are then played live over top of the sequence. No
> other modules other than my spring reverb. In the files section.
> Dave
2006-09-13 by djbrow54
--- In motm@yahoogroups.com, xamboldt <xamboldt@...> wrote:
> The HoldAllNotes function can also be created by using the sustain
> pedal, no? Am I missing something? (wouldn't be the first time!) :)
> -Chris
program:
notes.
sequence. No
> > Dave
2006-09-13 by J.D. McEachin
>I would expect so. It depends on how the 650 treats the pedal.The sustain pedal holds the first 16 notes played. That's the size of the note buffer, so sustaining the notes with an external keyboard or sequencer like Dave is doing won't increase that.
>I wanted no operator intervention so when I get a sequence I like then IMe too. The enhanced version of the firmware will have a similar foot-free "hold" feature, but with a twist. When "hold" is on, the sutain pedal can be used to add to the playing arpeggio. For example, play 3 notes, walk away from the keyboard and tweak the patch, then come back, press the sustain pedal and play a note, and the arpeggio will be 4 notes long. If you don't press the sustain pedal, the arpeggio is only 1 note.
>am free to do other stuff including wandering around.
2006-09-14 by djbrow54
--- In motm@yahoogroups.com, "J.D. McEachin" <jdm@...> wrote:
> At 03:23 AM 9/13/2006 -0000, djbrow54 wrote:>
> Here's something that Dave's program might not do - when holding
> the sustain pedal with the 650's arpeggiator, if ALL keys are
> released, they will arpeggiate until new notes are played. At
> that time, the old notes get dumped and the new notes start
> arpeggiating. I think that's pretty standard for midi
> arpeggiators. The enhanced version of the firmware will have a
> The cool thing about this is, you can double select notes
> in the arpeggio, say, ABACAB.
> Uh oh, I've probably given Dave too many ideas. ;)
> Jeffrey
2006-09-15 by J.D. McEachin
>Also,I'll have to see if there's enough RAM when I've got everything else working.
>anything to increase the length of the buffer from 16 would be great
>also.
>Any chance of sending the notes to midi out? I don't think theIt will be a feature in the upgrade. :)
>current implmentation does that.
