Index last updated: 2026-03-31 01:40 UTC
wavewarper problem
wavewarper problem
2006-08-06 by stiebz
there seems to be problem with my wavewarper,
if I give an input to the audio x input, I get no output whatsoever
independend of the knobsettings
the Y & Z seems to work OK, individually but also while 'warping'
I can read a voltage on the potmeter of X IN and the jack seems to
wired correctly, but other than that I have no clue what could be the
problem, anybody any idea ?
many thanks in advance !
steven
Re: [motm] wavewarper problem
2006-08-06 by Paul Schreiber
'X' is mainly a CV input, not audio (Y is the main audio input for warping).
To: <motm@yahoogroups.com>
Sent: Sunday, August 06, 2006 8:32 AM
Subject: [motm] wavewarper problem
> steven
2006-08-06 by Richard Bartz
short idea for a cool mod. why cannot X be an envelope follower ?
bg
rick
> Paul S.
> From: "stiebz" <theevaporizer@...>
>> steven
>> Yahoo! Groups Links
Re: wavewarper problem
2006-08-06 by Charles Osthelder
Better still, Rick - put a sine wave into audio x, an EG with a long
period into offset y, and any lfo output into z offset. Set the switch
to POWER. Watch your levels...
I could spend everyday with just the Wavewarper as the central
component of my patches! It does subtle timbres, extreme sidbands,
terrifying noises- all while allowing exceptional control through
modulation. Or destroying any chance of control - your choice!
If in the future Paul should be remembered for anything, I'll bet it's
this module. I got yer plain vanilla right here! All the other
so-called wave mangling modules are weak in comparison!
With the Wavewarper, just plug in and see what happens. Oh, and watch
your levels.
Chub
ps - did I mention that you should watch your levels?
> bg
> rick
warping).
> > Paul S.
> >> steven
> >> Yahoo! Groups Links
Re: [motm] Re: wavewarper problem
chub ... your words in gods ears ... i am watching my osciloscope the
whole day making wonderful graphics with the warper ; ) today i had a
180 degree spinning cogwheel. its like lsd !
yo !
> your levels.
> Chub
>> bg
>> rick
> warping).
>>> Paul S.
> the
>>>> steven
>>>> Yahoo! Groups Links
2006-08-06 by AtmoWorks.com
bummer...this one sounds fascinating..but looks like it's sold-out now..:(
James
2006-08-07 by stiebz
The problem I found was that with a sinus signal in both x and y
inputs, I do not hear any warping of the y signal, regardless of the
knob positions, also unplugging the x input makes no difference
with only a sinus signal to the x input I did some measuring :
On R1 ( resistor between pot and TL072 ) I can read a voltage, but on
the resistor R5 ( resistor after TL072 )I do not find any voltage.
Would that indicate that there is a problem with the TL072 ?
Steven
warping).
> Paul S.
whatsoever
to
> > steven
> > Yahoo! Groups Links
problem solved !
R4 wasn't soldered properly, silly me !
If you would excuse me now, I have some warping to do :-)
thanks for your help,
Steven
on
> Steven
for
> warping).
> > Paul S.
> > From: "stiebz" <theevaporizer@>
> whatsoever
while 'warping'
seems
> to
be
> the
> > > steven
> > > Yahoo! Groups Links
2006-08-09 by David Cornutt
That's the problem with the darn thing... I spend so much time making
cool patterns on the scope, that sometimes I forget about actually
making music with it!
2006-08-09 by Charles Osthelder
Good! Now use all low frequencies and use it to drive a VCO!
Chub - sick with wavewarper power!
