Small glorp with just a few MOTM modules
2006-06-10 by Richard Brewster
One of our list members, Jeremy, recently posted a question about module
selection and his initial choices:
300 VCO
440 VCF
101 Noise / S+H
190 VCA
390 uLFO
800 EG (I suggest getting two)
910 Mult
I thought it would be fun to make some patches with this exact set of
modules, as a demonstration.  Here they are:
This uses the 190 Ring Modulator with the 300 VCO sine wave and the 440
as a sine wave oscillator.  Half way through some pink noise is mixed in.
http://www.pugix.com/music/small-glorp-rm.mp3
This one also uses the 440 as an oscillator, but for dynamic linear FM
modulation of the 300.  One VCA is used for the dynamic FM and the other
VCA is used for volume.
http://www.pugix.com/music/small-glorp-fm.mp3
The third patch uses the 440 as a filter and also uses Pulse Width
Modulation on the 300.  The output goes in parallel through the two
VCAs, each controlled by an 800 EG.  This is why you want two EGs.  I
had no trouble using both EGs and both LFOs in these patches.  It was a
little harder to find a place for both VCAs.  This recording starts out
in mono, and at the 20-second mark I kicked in the Lexicon MPX-1 digital
post processor to add the "Classic Detune" effect.  You can see how it
creates a lively stereo field but does not alter the essence of the
sound.  The first two recordings also used the detune processing.
http://www.pugix.com/music/small-glorp-pwm-vcf.mp3
Multiples were used!  I made all of them with the Radio Shack Y adapters.
Cheers,
Richard Brewster
Re: [motm] Small glorp with just a few MOTM modules
I was mistaken about the third patch being mono.  The two VCAs go to
channels that are panned left and right.  The first two recordings
actually are mono, but with detuning applied.
-Richard
> 300 VCO
> 440 VCF
> 101 Noise / S+H
> 190 VCA
> 390 uLFO
> 910 Mult
> Cheers,
> Richard Brewster
Front Panel Touch Up
2006-06-10 by xamboldt
Anyone have any recommendations for how to touch up a scratched MOTM-
style front panel? I've got a panel with a few small scratches on it.
They're roughly 1-2 mm in length and about the equivalent width of a
printed 1-2 point line.
-Chris
Re: [motm] Front Panel Touch Up
2006-06-11 by Jay
Black Sharpie marker.
2006-06-11 by Paul Bower
hello there,
get yourself an Edding 8404 Aerospace Marker - they're designed for
writing on aluminium and perfect for filling in scratches
you can get them here in the uk from Rapid / Farnell / RS - so i
assume Digikey et al will also do them (or a US equivalent)
cheers
paul
> -Chris
> ------------------------ Yahoo! Groups Sponsor --------------------
> Everything you need is one click away.  Make Yahoo! your home page
> now.
> http://us.click.yahoo.com/AHchtC/4FxNAA/yQLSAA/VpLolB/TM
Paul Bower
Label Manager
Awal UK Limited
www.awal.co.uk
