Module order
Module order
2006-06-08 by Jeremy
Hi all,
I'm a rather silent member of the group here, but find this a very
valuable modular synth resource.
I'm after some advice on what would be a good group of modules to
purchase, to create self running glorpy glitchy soundscape type
noises?
I already have an 800 EG an 900 Power supply (just to test the
water, and my soldering skills).
My thoughs were towards the following. (all my buget will allow, for
the moment)
300 VCO -assembled
440 VCF -assmebled
101 Noise / S+H -kit
190 VCA -kit
390 uLFO -kit
910 Mult
Any help / ideas would be much appreciated.
Thanks for your time,
Jeremy.
Re: [motm] Module order
2006-06-08 by Paul Schreiber
> 300 VCO -assembled
> 440 VCF -assmebled
> 190 VCA -kit
> 390 uLFO -kit
> 910 Mult
I'd swap the mult for another EG. Mainly because right now, I'm out of '910s :)
2006-06-08 by Dino Leone
Jeremy,
go for the 300 kit. If you've successfully built an
800, then you'll be able to build the 300 too. Just
take it slowly. Make the 300 maybe the last module to
build on your list. I'd also go for the 440 kit. Or
maybe a 480 if you like the smooth Yamaha filter.
Apart from that you've listed the right modules for a
good and flexible starter system.
Best,
Dino
> of modules to
> soundscape type
> noises?
> to test the
> will allow, for
> the moment)
> 300 VCO -assembled
> 440 VCF -assmebled
> 190 VCA -kit
> 390 uLFO -kit
> 910 Mult
> Jeremy.
> Protect your PC from spy ware with award winning
> anti spy technology. It's free.
http://us.click.yahoo.com/97bhrC/LGxNAA/yQLSAA/VpLolB/TM
>     motm-unsubscribe@yahoogroups.com
Do You Yahoo!?
http://mail.yahoo.com
Re: Module order
2006-06-08 by Mike Marsh
For glorpiness, there's nothing like FM so I would add a second VCO.
If I had to substitute a module for that, I think you could do without
the mult...
Just one man's opinion :)
Mike
--- In motm@yahoogroups.com, "Jeremy" <jdkirk@...> wrote:
> Hi all,
> noises?
> the moment)
> 300 VCO -assembled
> 440 VCF -assmebled
> 190 VCA -kit
> 390 uLFO -kit
> 910 Mult
> Jeremy.
2006-06-08 by Matthew Hiscock
...and if you have a patch bay, you already have a mult.
On 7-Jun-06, at 9:31 PM, Paul Schreiber wrote:
> 300 VCO -assembled
> 440 VCF -assmebled
> 190 VCA -kit
> 390 uLFO -kit
> 910 Mult
www.bodega-audio.com
www.myspace.com/bodegaaudio
www.distillerymastering.com
Bodega./Bootleg Sounds. Fat East Coast. Distillery Mastering.
2006-06-08 by Eric Wood
You totally want that stuff!
Sent: Wednesday, June 07, 2006 8:04 PM
Subject: [motm] Module order
Hi all,
noises?
the moment)
300 VCO -assembled
440 VCF -assmebled
190 VCA -kit
390 uLFO -kit
910 Mult
Jeremy.
Re: Module order
2006-06-08 by elle_webb
> the moment)
> 300 VCO -assembled
> 440 VCF -assmebled
> 190 VCA -kit
> 390 uLFO -kit
> 910 Mult
Jeremy
It sounds like you're off to a good start. My suggestion would be to
go ahead and get the VCO assembled and get a VCA kit to build asap,
just so you can start making some noise. Once you know that you've got
those modules working, it will be easy to test new modules as you
build them.
By the way, the modules that Paul says are harder to build, like the
VCO's, mainly just take longer to build.
Here are a couple of other suggestions. You may want to consider the
380 quad LFO, instead of the 390. This would give you twice the number
of LFOs, and the ability to make complex LFO shapes easily.
You could probably hold off on the mult for now. When your system is
pretty small, you can get by with a couple of $3 Y-jacks from Radio
Shack.
Instead of the mult, you might put the money towards a uVCO. The
second VCO opens up a lot of possibilities for cross-modulation.
Hope this helps!
Re: [motm] Re: Module order
2006-06-08 by Richard Brewster
I'll chime in here.  You have made a good first selection!
When getting started you can use this sort of Y-adapter instead of a
multiple:
http://www.radioshack.com/product/index.jsp?productId=2103712&cp=&pg=3&origkw=adapter&kw=adapter&kwCatId=2032058
Later you will find the MOTM-910 useful, too.
As Paul said, a second MOTM-800 would be a good choice, because you have
two VCAs plus a VCF that all can use envelopes.  My opinion on the LFO
is that the 390 is more versatile than the 380, so I would get a 390
first.  You get square waves from it that you can use to trigger the
MOTM-101 and the 800s.  I use a 390 as a master clock like this in
almost EVERY patch.  Also, one of the two LFOs in the 390 is
voltage-controlled, so you can get random tempos if you feed back the
MOTM-101 to the FM input of the LFO.
To sum it up:  Substitute a MOTM-800 for the 910 in your list at first,
and get a couple of Radioshack Y-adapters.
Richard Brewster
http://www.pugix.com
>> the moment)
>> 300 VCO -assembled
>> 440 VCF -assmebled
>> 190 VCA -kit
>> 390 uLFO -kit
>> 910 Mult
> Jeremy
> build them.
> Shack.
> Hope this helps!
2006-06-09 by Seth Elgart
>multiple:
This reminded me that some time ago I saw on some web site a
"portable attenuator." It was a 1/4" plug with a pot and a 1/4" jack
all soldered together in a line. You could simply plug it into an
input on your synth and have an instant knob anywhere you wanted it.
Problem is, I can't seem to find it anywhere now. Ring any bells?
There were also a mini-mult or two in the same style. I wish I could
find them again.
       Seth
RE: [motm] Re: Module order
2006-06-09 by Chris Parker
Seth, is this what you're looking for?....go to www.moogarchives.com and click on "Oddities" and then "PortaPots".
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com]On Behalf Of Seth Elgart
Sent: Thursday, June 08, 2006 8:05 PM
To: motm@yahoogroups.com
Subject: Re: [motm] Re: Module order
>multiple:
find them again.
Seth
2006-06-10 by Seth Elgart
><http://www.moogarchives.com>www.moogarchives.com and click on
At 8:42 AM -0700 6/9/06, michael stein wrote:
>I know exactly what your talking about. It was called the port-a-pot
>and the port-a-mult, I believe. I think it was DIY and not for sale,
>but did not look hard to make. I will keep searching for a link, I
>saw it fairly recently.
Yes, thanks! That's exactly what I was looking for. I wouldn't mind
buying them, but they seem easily makable as well.
Thanks again.
         Seth
