FS: rack mount SEM1A
2006-06-02 by jpont@ksu.edu
For Sale: 19" rack mounted SEM1A
$525 [includes shipping within continental USA]
One SEM mounted in a 5U high by 19" wide black with white lettering rack
mount front panel with standard SEM inputs and outputs (see below for
list).  Front panel was manufactured by Front Panel Express.  Power
supply with AC cord, toggle switch (Fender amp switch) & LED is mounted
on the left of the front panel, the SEM in the middle, and input/output
sockets on the right. There are holes in the front panel for mounting a
backside enclosure, which I didn't have a chance to construct. The unit
is maximum 5" deep (power supply). Xerox of SEM manual (instructions,
schemtics, ...) included.
SEM is 10/10 electronic condition.  Cosmetic condition is 9/10, with
some minor edge marring near the upper left SEM mounting screw and both
vco fine trimmers are missing their end caps.
I have a photo, if you are *seriously* interested in buying this unit.
Input/output sockets (Switchcraft sockets, wired directly to SEM
locations [no Molex connections]):
Inputs:
cv for vco 1
cv for vco 2 (vco2 socket normaled to vco 1 socket)
vco 1 modulation
vco 2 modulation
filter frequency
trigger
gate
(2) external audio (into mixer)
vca control (which is not wired to the SEM)
Outputs:
filter high pass
filter low pass
filter band pass
filter resonance
lfo
audio
Please reply to jpont@....  Thanks, Jeff
