Roland 181 keyboard with MOTM
2006-05-29 by ivancu@aol.com
I finally found a Roland 181 keyboard on eBay to use with my MOTM.
Does anyone have any cautions on using these together?  I am planning
on replacing the 6-pin DIN connector with a 7-pin so that I can have
the bender output come through a multicable.  Will break that out in
the MOTM rack to separate jacks.
Ivan
Re: [motm] Roland 181 keyboard with MOTM
2006-05-29 by Scott Juskiw
I haven't found any problems using the two together. Just plug and
play. I think the 181 is actually better than some other controllers
because it has both gate and trigger outputs.
2006-05-30 by ivancu@aol.com
>I think the 181 is actually better than some other controllers because
In the case of the 181 what is the difference between its gate and
trigger outputs?
Thanks!
Ivan
