Index last updated: 2026-03-31 01:40 UTC
IC Sockets?
IC Sockets?
2006-05-07 by lfosynth2000
Hi Im building my first Motm modules.
I was wondering why Motm doesnt use IC socket for the IC chips?
Anybody know why?
Regards Azzer
Re: [motm] IC Sockets?
2006-05-07 by Mark
On 5/7/06, lfosynth2000 put forth:
>Anybody know why?
It does for rare or expensive chips. It doesn't, because sockets
increase the chance of mechanical failure, increase cost, increase
assembly time, and are generally unnecessary.
2006-05-07 by Richard Brewster
And in the rare case of needing to replace an IC, the MOTM PC boards are
high quality and easy to unsolder without damage to the board.
Richard Brewster
http://www.pugix.com
>>Anybody know why?
2006-05-08 by David Cornutt
Sockets are always a potential source of trouble. The contacts can
corrode or become weak and fail to make good contact, which
can lead to strange symptoms. And, if the module is subject
to a lot of vibration (say, while being trucked to a gig), it can
cause the ICs to fall out.
Occasionally, where a design has to use a particularly troublesome
part, Paul will put in a socket for that. But in most cases, you are
really better off without. I guess your concern is damaging an IC
with heat during soldering. Rest assured, decent soldering
technique will avert that problem. I'm nowhere near the best
solderer in the world, but I've built a number of modules and I
have yet to lose an IC due to soldering heat.
