820 Question
2006-04-28 by xamboldt
I'm currently building my 820 kit, and I've been planning a few mods (basically the oakley 820 mods done on a perfboard since the PCBs are no longer available). One thing I'm wondering about before I solder in the ICs - the bypass jack seems designed for a foot switch, but it also looks like it'll work with an external signal - if the signal is low, the lag is enabled, if the signal is high, the lag is bypassed. Does it work like that? There's 10K1 ohms of resistance between +V and the jack - if I did hook up another module's output to the bypass jack, could it hurt the other module? Basically I hacked together a method to use one of the unused CMOS switches and a comparator to enable the bypass jack to work with no problem with either a foot switch or an external voltage. Before I solder the CMOS switch in though, I want to know if I should bend the pins my mod would need out, or if I shouldn't bother since, for the reasons stated in the paragraph above, this mod might be unnecessary. Thanks for any help you can give! -Chris
