the sequencer
1999-12-01 by velure
paul or anyone... could someone please list somewhere a concise overview of the sequencer, its specs, and its size. i wish not to reinvent the wheel. -steve
1999-12-01 by Paul Schreiber
Which "sequencer"? The one Dave is building or the *official* MOTM one? Paul S. ----- Original Message ----- From: velure <velure@...> To: <motm@onelist.com> Sent: Wednesday, December 01, 1999 10:43 AM Subject: [motm] the sequencer > From: "velure" <velure@...> > > paul or anyone... > > could someone please list somewhere a concise overview of the sequencer, its
> specs, and its size. i wish not to reinvent the wheel. > > -steve > > >
> Which "sequencer"? The one Dave is building or the *official* MOTM one? the *official* one, duh. bring on the specs. -steve
1999-12-01 by Dave Bradley
The proposed Sequencer contains 2 rows of 8 pots and can store patterns of variable length for playback and realtime performance mangling. Here are some excerpts from previous posts from Paul on DOMOAS, "Daughter of Mother of All Sequencers" (I have omitted a zillion posts from everyone else discussing feature wish lists): >>>>>>> The knobs will be smaller diameter (same basic shape) plus there will be LEDs and an "date entry" rotary encoder + about 6 pushbuttons. <<<<<<< >>>>>>> DoMOAS is 7U wide and 5U tall. The +5V power for DoMOAS will be 3U wide (like the '900) so, 1 SEQ + 1 supply will fit in a rack. DoMOAS #2 needs it's own row :( The display I'm looking at is a Noritake 2x20 VFD dot matrix. Still thinking 7U wide, with a 3U wide "expander" module with individual outs (cv/Gate (trigger)/switch closure) for each stage. And, somewhere is the 3U wide MOTM-910 +5V 6A supply. <<<<<<< >>>>>>>> There are 99 memorys (#1-99). The length is set to say 16. You twiddle the 16 pots to the correct voltages, press <STORE>. (You 'alpha' in the location with the data entry knob). A <CHAIN> is another memory, that stores sequences of memory locations. A <CHAIN> might be: 1-2-45-3-74-1-70. In other words, it plays the notes in #1, followed by #2, followed by #45, etc. Of course, we could place a <HOLD> in the <CHAIN> until, say, a <GATE IN> is sensed. or a <HOLD/LOOP> that repeats the <CHAIN> over and over until <GATE IN> is active, then it proceeds. OR, a more bizarre <FORK>, which means if <GATE IN> is active *at that time*, go on, else branch to another <CHAIN>. Or a <HOLD CC>, which releases the <HOLD> if a MIDI CC message is active........ The joys of the lowly microprocessor. Take *that*, lowy Moog 960. <<<<<<< >>>>>>> Quick thoughts. 1) I plan to code in assembler, because a) the assembler is *FREE* b) the C compiler is $800 c) I have written over 600,000 lines of 8051 assembler code and 0 lines of C code d) I have *already written* 1/5th of the Seq code 1.0 already 2) The assembler code source will be posted to *encourage* hacking. People not hacking the code will be made fun of :) (Hack #1: have your name scroll across the display at power-up). 3) Yes, you can turn it into a a) ADADRSRDDARDR.... EG b) LFO c) MIDI-2-CV d) Sampler (!!?! heee hee) <<<<<<< >>>>>>> Note that the 80C320 is a "family" of high speed 8051 derivatives. Chances are, the actual part will be the 87C520. It has: a) 16K EPROM on-chip. This is where the Keil monitor resides, and the FLASH memory boot code. b) extra 1K SRAM for temp. variable storage. This is *real* handy! The actual Seq software resides in external FLASH, so we can update it using the 2nd serial port (the other serial port is dedicated to MIDI). The "patches" are stored in serial EEPROM (probably a Xicor 24C256). Hey, this is all d*****l crap! #@^$&#@$!!! <<<<<<< Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
> From: "velure" <velure@...> > > paul or anyone... > > could someone please list somewhere a concise overview of the > sequencer, its > specs, and its size. i wish not to reinvent the wheel. > > -steve >
1999-12-01 by The Old Crow
On Wed, 1 Dec 1999, Dave Bradley wrote: > 2) The assembler code source will be posted to *encourage* hacking. > People not hacking the code will be made fun of :) (Hack #1: have your > name scroll across the display at power-up). Heh heh, I did this to my old DX7. 6800 code is such a drag, though... --Crow /**/
