Phaser Modulation
Phaser Modulation
1999-12-01 by Tkacs, Ken
I remember reading an essay a long time ago about modulating
frequency-domain devices. It claimed that a sinusoidal LFO was a
less-than-ideal source for modulation because of the log nature of the
frequency/pitch spectrum. A sin (or triangle, if we're being cheap) tends to
"rush" through the lower frequencies and take "too long" to sweep high,
giving a vertically off-balance cycling.
This article claimed that the best way to modulate these kinds of devices
was a negative-cycle full wave rectified sine. In other words, a wave that
looks kind of 'spiky' like this:
(format this diagram with a monospaced font such as Courier)
_/ \__/ \__/ \__
Just thought I'd throw that into the discussion.
In fact, let me throw in another "beat the dead horse" comment:
Phasers work great with Shepard function generators as modulators...
Phaser Modulation
Agreed. Just thought I'd throw that into the mix; experimentation might bear
that out, in which case it might be cool to add that "rectified" wave to the
rotary switch or whatever selects the LFO waveform for the Phaser module.
Courier)
		> _/ \__/ \__/ \__
		>>> Well, that wouldn't be too hard to do.  Turning a sine
wave into a rectified sine is certainly easy enough. :)
Re: Phaser Modulation
1999-12-01 by J. Larry Hendry
> From: "Tkacs, Ken" <Ken.Tkacs@...>
that
> _/ \__/ \__/ \__
Well, that wouldn't be too hard to do.  Turning a sine wave into a
You have my curiosity up.  I will have to try some half wave and full wave
LFO modulations.  I never would have thought of that.
LH
> From: Tkacs, Ken <Ken.Tkacs@...>
> To: 'motm@onelist.com'
> Subject: [motm] Phaser Modulation
> Date: Wednesday, December 01, 1999 4:15 PM
bear
> 		-----Original Message-----
> Courier)
> 		> _/ \__/ \__/ \__
1999-12-02 by JWBarlow@xxx.xxx
In a message dated 12/1/99 7:34:20 AM, Ken.Tkacs@... writes:
>to
Thanks Ken! This was the point I was trying to make (not build in 2 MOTM 320s
into the Phaser). But I also think that other LFO waveshapes produce
identifiable (and popular) types of sweeps. For example, any LDR based phaser
would (presumably) have a characteristic type of sweep that might be worth
incorporating. If these could be implemented by VC (possibly by adding just a
few components for say $20), all the better! If not, oh well.
>_/ \__/ \__/ \__
I agree wholeheartedly, maybe down the road apiece Paul will introduce one --
given time for us to acquire 8 VCOs, 8 VCFs, 8 Phasers, etc.
And Ken, this phaser will undoubtedly have a "KILL" setting! For self
destruct, it is often just enough to plug the modules output into its input.
John B.
Oh yeah! Pole switching is nice and an envelope follower (even a cheesy one)
might be an interesting idea, I've never tried it before.
1999-12-02 by DAVEVOSH@xxx.xxx
In a message dated 99-12-01 09:34:22 EST, you write:
<<  negative-cycle full wave rectified sine. In other words, a wave that
 looks kind of 'spiky' like this: >>
ken, if my memory serves me correctly this sort of idea was used by craig
anderton in the ( kit by paia ) hyperflange and chorus. this same sort of
waveshape is producable via a dsg ( by another manufacturer ) feeding the
envelope back into the control input and using negative biasing. using
positive biasing produced a sort of overrounded / convex kind of waveshape.
both were neat for assorted control purposes, phasing and otherwise.
best,
dave
1999-12-02 by The Old Crow
On Thu, 2 Dec 1999, J. Larry Hendry wrote:
> Dave, I do happen to have the old Hyperflanger schematic.  It is built
> around a SAD1024 and 571.  I can send you a copy if you like.
  It also uses a CEM3340, if I recall.  $50 chip these days.
1999-12-02 by Elhardt@xxx.xxx
jlarryh@... writes:
>>But, I do not agree with the general concept that feature reduction because
 of incremental cost increases should be an icon of MOTM design.  If MOTM
 really means Mother of the Modulars, or Modular of the Millennium, then it
 should be just that.<<
I don't like to see compromises made either.  But when somebody is asking for
the functionality of the MOTM-320 LFO to be placed in the Phaser, that is
going too far.  Keep in mind, virtually all modular synths that have phaser
modules don't provide any internal modulation at all.  You are expected to
use other modules for that.  So the MOTM phaser has already gone beyond the
others in that area.  The places to spend more money on are the phase shifter
itself.  As I suggested before, negative feedback.  How about a rotatary
switch to allow the user to choose 4,6,8,10,12 stages of phase shift like the
Moog 12 stage phaser?  Someone else mentioned spreading/contracting the
phaser bands/notches apart, for totally different phaser sounds.  The Nord
Modular does that, and it gives you thousands of different phaser tones.
These are the places to add features.
-Elhardt
1999-12-02 by J. Larry Hendry
> From: DAVEVOSH@...
waveshape.
> best,
> dave
LH
> From: Elhardt@...
> somebody is asking for the functionality of the MOTM-320
> going too far.
Agreed.  I'm not sure anybody really intended that.  Heck, that's what the
320 is for.
to
shifter
Ooh. That sounds cool.  I like rotary switches.  And, standard MOTM knobs
are big enough to handle the job.
LH
> From: The Old Crow <oldcrow@...>
Of course.  Silly me sitting here looking at only the audio section of the
thing.  The modulation section of the schematic does indeed have a 3340
along with CMOS 4046 and 4041, and of course some op amps.
I certainly would never build from this schematic especially when Paul is
making us such a super one.  However, the good news is that Paul's December
sale has reduced the price of CEM chips.  :-)
I was looking to see if I could identify the feature that Dave was talking
about.  It isn't jumping out at me.  But then, I don't see as well as I
used to. :-)
LH
RE: Phaser Modulation
1999-12-02 by Tkacs, Ken
My $0.02:  This reasoning makes perfect sense to me.
are expected to
gone beyond the
the phase shifter
about a rotatary
sounds.  The Nord
phaser tones.
