Archive for motm.
New MOTM switches found
1999-03-17 by Paul Schreiber
I have decided that after a new member recently joined the
"Rip the Switches" society, it was time for a change.
So, I am going to see if Mouser will take back $400 worth of switches
tomorrow.
The new candidate is from NKK Switches. Allied sells them but I don't like
their prices!
But, I did get two of them and did the MOTM/ISO-9009 "Larry the Mad Torquer"
test.
I am happy to report that these puppies hold up extremely well >>>>IF<<<<<
you follow
my directions: these have a longer threaded bushing *on purpose*. You put
the first hex nut
on the bushing *but NOT touching the base of the switch*!! In other words,
unlike the panel pots
where we thread the nut until it is touching the body of the pot, we want
the nut about 3 turns
OFF the base of the switch. The bushing is long enough to then add a
lockwasher, pass it thru the hole
(thankfully uses the exact same hole!!) and the apply aforementioned
MOTM/ISO 9009 test.
Free VCO kit to the person who correct analyzes the aforementioned paragraph
on why it is done
this way. OK, no free VCO kit but satisfaction in engineering
problem-solving.
Also, since TANSTAAFL, the new NKK switches are TWICE as expensive as the
Mouser ones.
But, they do have the same handle style. I will have to modify the
instructions because they do not have the
'1 2 3' indications as the Mouser ones did. Isn't synthesizer design
glamourous??!?
has a big headache
Re: New MOTM switches found
1999-03-17 by mmt
Hey Paul,
Did you ever look into the type of switches used for guitar pickups?
They give a nice "klunk" when switched. Of course they are quite a bit more
xpensive, but also near industructible.
just an Idea.
Mark
To: MOTM listserv <motm@onelist.com>
Date: Tuesday, March 16, 1999 9:30 PM
Subject: [motm] New MOTM switches found
>From: "Paul Schreiber" <synth1@...>
>tomorrow.
>their prices!
Torquer"
>test.
>you follow
>the first hex nut
>MOTM/ISO 9009 test.
paragraph
>on why it is done
>problem-solving.
>Mouser ones.
>glamourous??!?
>Paul S.
>has a big headache
>Did you know that we have over 85,000 e-mail communities at Onelist?
>http://www.onelist.com
>Come visit our new web site and explore a new interest
1999-03-17 by JWBarlow@xxx.xxx
In a message dated 3/16/99 6:30:13 PM, "Paul Schreiber" <synth1@...>
>tomorrow.
Hi Paul,
Good decision! But it's possible that boneheads like me might want to buy some
of these old style switches from you, if only to replace broken ones or use
for mods. I'd be interested in anywhere from 5 (min) to 20. Maybe these could
be sent to us with the VCO kits (I haven't reserved my one kit, but you MUST
know I'm ordering one as soon as they are available!). Anyone else thinking
this?
Larry! Did you notice when it was just you and me bustin the switches it was
OK; BUT NOW a NEW MOTM MEMBER busts a switch, and everything changes. Welcome
to the synth peon club Larry!
JB
1999-03-17 by mmt
OK,
Lets let Paul settle it - who was the Original Switch Buster?
I busted mine around June '98 - on the MOTM-100
I'm staying up too late again.
Mark T
To: motm@onelist.com <motm@onelist.com>
Date: Tuesday, March 16, 1999 11:18 PM
Subject: [motm] Re: New MOTM switches found
>From: "J. Larry Hendry" <jlarryh@...>
>>>>---- snip ---<<<
>> Mad Torquer" test.
>As the founding member of "Rip the Switches" society, I would like to
>point out that the official "Larry the Mad Torquer" test was not an
>accident
>of misguided wrist muscles. For years, I have been exercising and toning
>my wrist muscles to be the official "MOTM mechanical integrity quality
>assurance engineer. I take my role seriously and claim sole responsibility
>for the quality enhancements announced by this manufacturer as the result
>of my tests.
>Please remember that the mechanical testing laboratory is supported by user
>dues. Please remit your 1999 dues as soon as possible if you have not done
>so already. Your support is appreciated. In case you have forgotten,
>annual
>dues are $2 annually for each module in your system on January 1.
>>>>>IF<<<<<
>> you follow my directions: these have a longer threaded bushing *on
>purpose*.
>> You put the first hex nut on the bushing *but NOT touching the base of
>the
>> switch*!! In other words, unlike the panel pots where we thread the nut
>until
>> it is touching the body of the pot, we want the nut about 3 turns OFF the
>base
>> of the switch. The bushing is long enough to then add a lockwasher, pass
>it
>> thru the hole (thankfully uses the exact same hole!!) and the apply
>aforementioned
>> MOTM/ISO 9009 test.
>Seriously, thanks Paul. I have always thought this type of tightening was
>best
>for switches.
>paragraph
>> on why it is done this way. OK, no free VCO kit but satisfaction in
>engineering
>> problem-solving.
>Well, no pressure is placed on the base of the switch. The bushing is not
>pulled
>away from the switch base. Instead the nuts are tightened against each
>other
>putting all pressure on the bushing threads. And, the nut on the back
>holds the
>lock washer against the back of the panel better that the switch base does.
>MOTM subscribers,
>Don't forget. Send those dues!
>Larry Hendry
>New hobbies? New curiosities? New enthusiasms?
>Sign up for a new email list today
1999-03-17 by J. Larry Hendry
>>>---- snip ---<<<
> Mad Torquer" test.
accident
of my tests.
annual
>>>>IF<<<<<
purpose*.
until
base
it
aforementioned
> MOTM/ISO 9009 test.
best
for switches.
paragraph
engineering
> problem-solving.
pulled
other
holds the
MOTM subscribers,
Larry Hendry
> From: JWBarlow@...
Hey, March 15th was the date orders were accepted I think. I ordered VCO #
1 and # 2. And, took Paul up on the Pro 2000 discount offer.
> Anyone else thinking this?
Not I. I was actually thinking of ordering some of the new ones direct
from Mouser with the part number Paul supplied to replace my old ones in
modules built so far.
was
Welcome
Your condolences are appreciated John. <<snif..snif>>
> From: "mmt" <mmt@...>
> Mark T
Not necessary Mark. Larry the Torque Monster busted BOTH switches on
MOTM-110, which was the first MOTM release ahead of MOTM-100. <g>
LH
1999-03-17 by Dave Bradley
So, if you put the lock washer behind the panel, what keeps the hex nut on
the front from chewing up the finish as it is tightened directly against the
paint? Or do you hand tighten it, then torque the nut behind the panel?
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
> you follow
> the first hex nut
> MOTM/ISO 9009 test.
> on why it is done
> problem-solving.
Right now, nothing. Although I found you are more likely to
scratch the smooth paint on the back of the panels than the textured
paint on the front. Unfortunately, the switches do not come with
a front washer like the jacks and pots do.
But, I haven't seen any evidence of scratching the front panel paint
from nut tightning.
Date: Wednesday, March 17, 1999 9:05 AM
>From: "Dave Bradley" <daveb@...>
>Dave Bradley
>daveb@...
>>>>IF<<<<<
>> you follow
>> the first hex nut
words,
>> MOTM/ISO 9009 test.
>> on why it is done
>> problem-solving.
>Have you visited our new web site?
>Onelist: Helping to create Internet communities
1999-03-29 by Paul Schreiber
1) Yes, the NKK switches have arrive, and Mouser did take back the old ones.
I am
keeping a few old ones for "pure vintage" folks. The NKK switches have less
actuation
force, but the exact same handle and MUCH stronger bushing threads.
2) RS owns the largest analog meter movement factory in China.
Date: Sunday, March 28, 1999 9:14 PM
>> tomorrow.
>like
>> their prices!
>Torquer"
>> test.
>Did you decide to go with these switches for the new modules? BTW, I was
>in RS today picking up an overpriced project box and see they carry a
>switch with the same exact handle we are using on MOTM. You don't EVEN
>want to know the price on theirs.
>I was shocked to find RS had good looking 15 VDC meters for 1/3 the price I
>paid for mine. According to the specs they were almost as good. But right
>there, tamped on the scale was "Radio Shack." Damn, why did they have to
>go ruin it like that.
>Larry.
1999-03-29 by J. Larry Hendry
> tomorrow.
like
> their prices!
Torquer"
> test.
Larry.
1999-03-31 by J. Larry Hendry
like
> their prices!
> Mouser ones.
> glamourous??!?
I am looking for these switches in the Allied Catalog. I do not find any
identified TANSTAAFL. Am I missing something. I found what "appears" to
be the right one on page 232 of Catalog 980. The NKK number for the SPDT
no center position is M2012ES1W01. Is this the switch you are talking
about?
