Hi Josh,
You don't need a special patch. Try this test. Patch a signal into IN2
and monitor OUT2. Don't patch anything to CV2. If you turn the middle
pot (GAIN) up all the way, you should hear something coming out whether
it is in Linear or Exponential mode. If you only hear something in
Linear mode, then it's not working right.
In the Exp mode at CV levels below 3V the output will be very small.
That is normal.
-Richard Brewster
http://www.pugix.com
jbarnett2323 wrote:
>Hello all
>I am new to modular synths and I have a question, my 190 VCA seems to
>be working fine in Linear mode, but I cannot even get audio with Exp mode.
>Can someone let me know a simple patch which should give audio, or is
>this thing not working correctly.
>Thanks
>Josh
>Yahoo! Groups Links
