Tannerin: Was: Controllers for modulars
1999-11-30 by J. Larry Hendry
From: DAVEVOSH@... > << Tannerin >> > > larry, > let me trot out my ignorance once again and ask what this is supposed to be? > i`ve never heard of it but you made it sound interesting! > best, > dave Dave a Tannerin, as the name has been coined after the guy that built the first one, Paul Tannerin, is an alternate controller for oscillator frequency. It was the instrument used to make the sliding oscillator sounds on the Beach Boys song "Good Vibrations" Many people mistakenly believe this was a Theremin. The Tannerin essentially produces a similar output to the Theremin. However, as anyone who has ever tried to play a Theremin will testify (I own one), it is virtually impossible to pick those notes out of thin air. So, the Tannerin transfers that control to a slider that travels along a horizontal surface. A keyboard can be "drawn" on that flat surface showing where to "slide" the control to so that you get in the vicinity of the correct pitch. I think the original Tannerin (and some of the Tom Polk designs) have a pot operated with the left hand to control volume output of the internal oscillator. These were originally designed as "stand alone" instruments. However, one can see how a simple CV output would make them a relatively cool modular controller. Tom is working on the final stages of a CV Tannerin as we speak. I think to be a good modular controller, one would need to add some method to generate gates or gate / triggers. Dave B asked for the URL again, so here is Tom Polk's URL with information about Theremins and Tannerins, along with links to other sites where you can find more. Be sure to check out Dave Millers Tannerin, built by Tom. > http://www.tompolk.com Scroll down past the real estate parts to the "home built instruments" link. Enjoy, Larry Hendry
