Moog Cabinet comment
1999-11-30 by Eric S. Crawley
After looking through the archives at some of the cabinet discussions, I
think there is an interesting feature of the sloped Moog cabinets that some
folks might have missed.  The bottom row of "half panels" are hinged to the
base of the cabinet which is also why the bottom edge is larger than the
top edge.  It is a simple piano-type hinge  that allows you to flip down
the lower panel for access to the backside of the panel.  Those who are
building cabinets like this might want to think about hinges.  With a
sloping front panel, it is a real pain to get at the lower panel from the
rear of the cabinet.  You will appreciate the ability to get at the lower
panels if they are hinged.
Also, there is a wood brace that goes across the cabinet that holds the
rails for mounting the top of the half panels and the bottom of the full
panels.  This brace fits into a slot on the cabinet side and is glued in
place.
Anyway, I thought this might be benefical to the cabinet builders out
there.  I'm building a Moog-style upper cabinet.  I just ordered my first
modules this evening.  When I get the plans done, I'll pass them on.  27U
wide looks quite possible now!
	Eric
