Fw: [motm] gate processor preview
2006-02-23 by Paul Haneberg
Sorry, this was meant for the group, not just for John Paul H. ----- Original Message -----
From: "Paul Haneberg" <phaneber@...> To: "John Loffink" <jloffink@...> Sent: Wednesday, February 22, 2006 11:02 PM Subject: Re: [motm] gate processor preview > Okay, I'll be more specific > > The countersunk screw holes do not conflict with the .5U mounting hole > locations. > You can use any combination of .5U and 1U spaced modules across rail > boundaries and at any locations. > Here's all the numbers. > If you still think it won't work, draw it. > > 1U=1.75" > .5U=.875" > > Mounting Holes are centered .25 from the module edges. > > Assuming the left end of the Flat Rail is at 0" > The following are the centers of the hole locations going along the X > axis: > > .25" - 1U mounting hole > .625 - .5U mounting hole > .875" - Countersunk hole for wood mounting > 1.125" - .5U mounting hole > 1.5" - 1U mounting hole > 2.0" - 1U mounting hole > 2.375" - .5U mounting hole > 2.875" - .5U mounting hole > 3.25" - 1U mounting hole > 3.75" - 1U mounting hole > 4.125" - .5U mounting hole > 4.375" - Countersunk hole for wood mounting > 4.625" - .5U mounting hole > 5.0" - 1U mounting hole > 5.5" - 1U mounting hole > 5.875" - .5U mounting hole > 6.125" - Countersunk hole for wood mounting > 6.375" - .5U mounting hole > 6.75" - 1U mounting hole > 7.25" - 1U mounting hole > 7.625" - .5U mounting hole > 8.125" - .5U mounting hole > 8.5" - 1U mounting hole > 9.0" - 1U mounting hole > 9.375" - .5U mounting hole > 9.625" - Countersunk hole for wood mounting > 9.875" - .5U mounting hole > 10.25" - 1U mounting hole > 10.5" - Other end of Flat Rail > > 1U module boundaries would be at: > > 0.0" > 1.75" > 3.5" > 5.25" > 7.0" > 8.75" > and 10.5" > > .5U module boundaries would be at the above plus: > > 0.875" > 2.625" > 4.375" > 6.125" > 7.875" > 9.625" > > The clearance at the edges of the countersunk holes is tight, but there is > no conflict. > > Try it, it works. > > Paul H. > > > > > ----- Original Message ----- > From: "John Loffink" <jloffink@...> > To: "'Paul Haneberg'" <phaneber@...>; <motm@yahoogroups.com> > Sent: Wednesday, February 22, 2006 9:41 PM > Subject: RE: [motm] gate processor preview > > >> ? >> >> The countersunk screw holes conflict with some of the 0.5U mounting >> locations. >> >> John Loffink >> The Microtonal Synthesis Web Site >> http://www.microtonal-synthesis.com >> The Wavemakers Synthesizer Web Site >> http://www.wavemakers-synth.com >> >> >>> -----Original Message----- >>> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of >>> Paul >>> Haneberg >>> >>> No, this assumes you could mount panels in 1.5U or .5U increments across >>> 6U >>> flat rail boundaries. >>> The only assumption would be that you have a total of X*6U, (unless of >>> course you cut down a flat rail or two) >>> >>> Paul H. >>> >> >> >> >> >> Yahoo! Groups Links >> >> >> >> >> >> >> >
