VC LAG
VC LAG
2006-02-19 by ithaib
Hi everyone,
I'm experimenting with my new VC LAG, and the only thing I don't understand is how to use
the 3 Up/Down/Up & Down Inputs. They accept Control Voltages, right? Why do they not do
anything? What am I not doing right?
Thanks for any help...
Ithai.
Re: VC LAG
2006-02-20 by mate_stubb
Besides the possibility that it has an assembly error and does not
work, could it accidentally be in bypass mode? Bypass switch mounted
upside down? Is the bypass LED lit?
Moe
--- In motm@yahoogroups.com, "ithaib" <ithaib@...> wrote:
> Hi everyone,
Why do they not do
> Ithai.
Re: [motm] Re: VC LAG
2006-02-20 by Richard Brewster
Yes.  It is almost certain that if the UP, DOWN, and UP/DOWN pots work
as expected, the corresponding VC inputs also work.  They go right to
the pots.
Remember, too, that the VC inputs are mainly useful with very *slowly
changing* control voltages.  The CV going in would normally be changing
at a slower rate than the slew being imparted.  A very slow LFO, EG, or
a sample & hold being clocked at a slow rate would be the type of CV to
use.  A fast CV here might not have much of an effect.
-Richard Brewster
http://www.pugix.com
>Moe
>>Hi everyone,
>Why do they not do
>>Ithai.
>Yahoo! Groups Links
Re: VC LAG
2006-02-21 by ithaib
Got it, thanks....
I fed an LFO into the inputs and it turns them on and off. Maybe when I did it before the
LFO was going too fast? Maybe I was dreaming....
Thanks!!
Ithai.
> the pots.
> -Richard Brewster
> >Moe
> >--- In motm@yahoogroups.com, "ithaib" <ithaib@> wrote:
> >>Hi everyone,
> >Why do they not do
> >>Ithai.
> >Yahoo! Groups Links
2006-02-21 by Overand
That is actually not the proper behavior of these inputs.  The CV inputs are the equivalent of turning the up, down, up/down pots themselves.  there s a
Re: VC LAG
No offense taken....
What I meant though was that I got them to work. with an LFO it's easy (and you can
actually get a cool effect with it, it kicks in randomly while you're playing. I think you're
right - from what I see, when the LFO goes into negative it turns the slewing off
completely) I also controlled the amount of slewing with an EG, which I think is more like
what you're saying.
At first I was thinking of the CV inputs the wrong way, that's why I wasn't hearing
anything.
Thanks!
More experimenting to do...
Ithai.
> the equivalent of turning the 'up, down, up/down' pots themselves.  there's
> a probability (paul?) that the LFO going into negative would have a negative
> (heh) effect, that is, the CV inputs may only be designed to accept positive
> control voltages, and the LFO provides a +-5volt peak to peak.
> I do **not** mean to be insulting here, but perhaps reading a primer on how
> modular synths work would help.  CV inputs for most modules work more or
> less the same as these.  The unfortunate thing is that this is not a really
> easy or intuitive module with which to learn the ins, outs, and 'feel' of
> using CV control instead of a knob.
> Nothing is a substitute for hands-on expereience, but if you have a limited
> array of modules in your rig, hands-on learning of the 'basics' (again, no
> insult intended) might be difficult, so reading up would probably be
> helpful.
> It's possible that I have totally misunderstoor, and if so, I apologize, but
> again, I mean no insult to you.  We all start somewhere, and modulars, while
> pretty damned intuitive with experience, are pretty arcane beasts and can be
> very intimidating and confusing.  Occasionally the specific details of hte
> operation of one of my modules still conufses me, specificlaly my MOTM 190
> uVCA, which is a very important and widely used module!
> Best wishes, good luck and happy tweaking (and patching)!
> -Geoff
> ithaib wrote:
> Got it, thanks....
> it before the LFO was going too fast? Maybe I was dreaming....
> Thanks!!
> Ithai.
> --- In motm@yahoogroups.com, Richard Brewster <pugix@> <pugix@> wrote:
> Yes.  It is almost certain that if the UP, DOWN, and UP/DOWN pots work as
> expected, the corresponding VC inputs also work.  They go right to the pots.
> changing* control voltages.  The CV going in would normally be changing at a
> slower rate than the slew being imparted.  A very slow LFO, EG, or a sample
> & hold being clocked at a slow rate would be the type of CV to use.  A fast
> -Richard Brewster
> Moe
> Hi everyone,
> Why do they not do
> Ithai.
2006-02-25 by Geoff
are the equivalent of turning the 'up, down, up/down' pots themselves.
there's a probability (paul?) that the LFO going into negative would
have a negative (heh) effect, that is, the CV inputs may only be
designed to accept positive control voltages, and the LFO provides a
I do *not* mean to be insulting here, but perhaps reading a primer on
how modular synths work would help.  CV inputs for most modules work
more or less the same as these.  The unfortunate thing is that this is
not a really easy or intuitive module with which to learn the ins, outs,
and 'feel' of using CV control instead of a knob.
limited array of modules in your rig, hands-on learning of the 'basics'
(again, no insult intended) might be difficult, so reading up would
probably be helpful.
but again, I mean no insult to you.  We all start somewhere, and
modulars, while pretty damned intuitive with experience, are pretty
arcane beasts and can be very intimidating and confusing.  Occasionally
the specific details of hte operation of one of my modules still
conufses me, specificlaly my MOTM 190 uVCA, which is a very important
-Geoff
ithaib wrote:
>Got it, thanks....
>Thanks!!
>Ithai.
>>the pots.
>>-Richard Brewster
>>>Moe
>>>>Hi everyone,
>>>Why do they not do
>>>>Ithai.
>>>Yahoo! Groups Links
>Yahoo! Groups Links
2006-02-25 by Geoff
-Geoff
ithaib wrote:
> Got it, thanks....
> I did it before the LFO was going too fast? Maybe I was dreaming....
> Thanks!!
> Ithai.
>> work as expected, the corresponding VC inputs also work.  They go
>> right to the pots.
>> changing at a slower rate than the slew being imparted.  A very slow
>> LFO, EG, or a sample & hold being clocked at a slow rate would be the
>> type of CV to use.  A fast CV here might not have much of an effect.
>> -Richard Brewster
>>> Moe
>>>> Hi everyone,
>>> Why do they not do
>>>> Ithai.
