Vocal Filter?
Vocal Filter?
2006-02-17 by Mike Marsh
Is there such a thing as an analog vowel filter?  these are often
featured on VA's (Micro Modular, Vaz, etc.) but I haven't seen one as
a real module.  They are really cool and I'd love to add one to my rig...
Mike
Re: [motm] Vocal Filter?
2006-02-17 by Jason Proctor
any collection of resonant bandpass filters in parallel can be a
vowel filter. you just have to crank the resonance and get the centre
frequencies right.
the motm-410 can do this all by itself, just turn off the LFO mod. i
think there's a vocal sample up on the 410 page, even.
what filters do you have? minimum config for this trick is two
resonant lowpass filters (and preferably some EQ).
>Mike
Re: Vocal Filter?
2006-02-17 by elle_webb
rig...
> Mike
There's some interesting info over at Wikipedia about formants:
http://en.wikipedia.org/wiki/Formant_synthesis
You can get some vocalesque sounds using the 410.
Anyboy have a recipe for a good MOTM-based vocal sound?
Re: Vocal Filter?
Thanks to all that replied!
I've used the 410 in this way and to some degree the 420.  The 410
does not have *quite* enough resonance but I can remedy that by
feeding it back into itself.  It's still kind of static, though.
The filters I've used in VA's have morph between a series of vowel
sounds (eeee-aaayyy-ohhhh-oooo) and at high resonance you can get some
woody timbres from low frequencies.
I was just wondering if it's even possible in the analog domain at a
reasonable price?
Mike
> rig...
> > Mike
Re: [motm] Re: Vocal Filter?
2006-02-17 by Paul Schreiber
You need a series of high-Q bandpass filters with variable gain. Like a filter
section of a vocoder (cough).
www.synthtech.com/demo/jh_freeze_ahh_1.mp3
www.synthtech.com/demo/jh_freeze_ohh_1.mp3
well... if you need to VC the bandpass frequencies to get morphing,
you could add the oakley 410 expander to your 410.
however it's tough to compete with something like a nord micromodular
for stuff like this. does doepfer have a vc filter bank perchance?
>reasonable price?
>Mike
RE: [motm] Re: Vocal Filter?
2006-02-17 by John Loffink
Jim Patchell had a DIY project for vocal filtering:
http://www.oldcrows.net/~patchell/synthmodules/vocalfilter.html
PCBs no longer available, though he provides gerber files if you want to
make your own.
John Loffink
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Mike
> Marsh
> reasonable price?
2006-02-18 by Richard Brewster
Electronotes #102, June 1979, is entirely devoted to Bernie Hutchins'
Vocal Effects Waveform Animator (VEWA).    It is comprised of three
state-variable VCF's with bandpass outputs, a fixed bandpass filter, and
a VC notch filter.  These are driven by a bank of five VC LFO's.  It
uses a boatload of CA3080 chips.  The article is worth a read, even if
you don't want to build something like this yourself.
-Richard Brewster
http://www.pugix.com
>Mike
>Yahoo! Groups Links
I want that Vocal Filter!!
2006-02-18 by Dana Countryman
> make your own.
> John Loffink
> http://www.wavemakers-synth.com>>
Most awesome and funny sounds I've heard out a synth in a long time!
Man! I'd sure like to have something like this....
I wonder what the front panel looked like....
- Dana
http://www.danacountryman.com
2006-02-18 by Kenneth Elhardt
Mike Marsh writes:
a real module.<<
Any vocal filter I have in a VA synth sounds lousy.  The only advantage they
have is that you can morph between vowel sounds with a single control.
You're better off with 12 db/oct resonant lowpass filters or 24 db/oct next
choice.  For some reason even the AS-360 Vocal/Phase 3 band filter bank
doesn't do as good a job as using separate filters.
elle_webb writes:
>>Anyboy have a recipe for a good MOTM-based vocal sound?<<
I've posted the demo below a while back.  It's an motm female voice played
against a recording of an orchestra, plus a couple of Doepfer male voices
that you can really only hear for a couple of seconds right at the
beginning.  Filesize: 930KB.
http://home.att.net/~elhardt2/MOTM_Female_Voice.mp3
Filters used were a 440 for preprocessing of the waveform, one 410, two 420s
(one in LP and one in HP), a 31 band EQ, and a VT-1 to move all the formants
around in one bulk.  I also must point out, there is also more to getting
good vocal sounds than just the filtering.  It's also about what gets fed
into the filters, and as in the Ion demos below, what's done after the
filters too.
Jason Proctor writes:
>>does doepfer have a vc filter bank perchance?<<
Yes.  They have a triple bandpass filter bank that is similar to some degree
to Analog Systems AS-360.
>>minimum config for this trick is two resonant lowpass filters (and
preferably some EQ).<<
That's the method used for most of this also previously posted Ion demo I
did showing a number of subtly different mellotron style choir patches.
Filesize: 2.24MB
http://home.att.net/~synth6/Ion_Tomitas_Mellotron.mp3
And below at about the 0:06 point is the Ion patch kind of saying "Wah" by
controlling the two filters with envelopes.
http://home.att.net/~synth6/Alesis_Ion_Western.mp3
-Elhardt
2006-02-18 by john mahoney
> ... Like a filter section of a vocoder (cough).
What kind of a tease is that?! ;-D
Did everyone else miss it, or am I reading too much into it?
john (after a night out that included Ethiopian food -- really!)
2006-02-18 by Dino Leone
I assume he's referring to that vocoder that JH
designed and that would be more or less ready for MOTM
production. I forget (for a good reason) how many
frequency bands that thing has (18?)....
Best,
Dino
--- john mahoney <jmahoney@...> wrote:
> From: "Paul Schreiber"
> into it?
> -- really!)
>     motm-unsubscribe@yahoogroups.com
Do You Yahoo!?
http://mail.yahoo.com
Re: Vocal Filter?
2006-02-18 by mate_stubb
He's referring to the Mother of All Vocoders. The filter section
prototype was built long ago, but I haven't heard any news since. It
was contemplated as rack mount, many bands, and many dollars.
Moe
http://www.stoogeindustries.com
RE: [motm] I want that Vocal Filter!!
2006-02-18 by John Loffink
It has 43 knobs according to the front panel schematic.  I believe that's
past the point where a pure analog implementation becomes more troublesome
than useful, and some programmability is required, for memorizing all those
settings.
John Loffink
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Dana
> Countryman
2006-02-18 by eric f
Paul had posted early last year that the price on such a unit, a sort of dream project, was $2.8k and I can only assume that that figure would be higher today.
I'd buy it because I know it would be one of my most utilized pieces of kit. And I think there's an audience outside the modular community for such a beast as well. I don't know how large that audience is, but judging from some of the prices the old vocoders are going for, it's there.
cheers,
eric f
Moe
2006-02-19 by Mark
Although not as controllable, envelope filters can be used to create
vocal sounds.    A friend of mine often made his TB-303 "talk" by
running its output through two Mutron III's in series :)
2006-02-19 by John Loffink
It appears that Analog-Labs is releasing a comparable vocoder product.
Pre-release price appears to be 1290 Euro.
http://www.analog-lab.com/x32-fr.htm
John Loffink
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of eric f
higher today.
  _____
2006-02-19 by john mahoney
higher today.
Yes, I remember that discussion, now. Thanks! The concept was a 21-band
vocoder. Somebody suggested breaking it up into smaller units, so I
suggested a 7-band version (you could use 1, 2, 3, or more).
john
2006-02-21 by Matthew Hiscock
Gotta say - that sounds ridiculously good. Or as they might say: "Ça,
c'est dingue!"
Matthew
> product.  Pre-release price appears to be 1290 Euro.
> John Loffink
> eric f
> SPONSORED LINKS
> Label
> Cd music label
> Independent music label
> YAHOO! GROUPS LINKS
> 	▪ 	 Visit your group "motm" on the web.
> 	▪ 	 To unsubscribe from this group, send an email to:
> 	▪ 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
www.bodega-audio.com
Bodega/Bootleg Sounds. Fat East Coast. Distillery Mastering.
2006-02-21 by Marc Bareille
Hi John,
I think the info did not cross yet  the oceans very well  whatever some
web sites say...
the X32 has been released 2 years ago (2004)  ... so it is not a "pre
release" at all  but a full sales status ... It has been presented at
the Francfurt Music messe last year too
1290 euros is the actual public price you can get at any music shop who
distribute our products ( mostly in the EU area ...but i hope this will
change soon)
I know well  the Analog Labs compagny as they are located just nearby
where i live . I am working for them since few monthes ( design of new
products and  after sales services/repairs/ customs mods...)
I also have a X32 at home so  if you need more infos about this unique
beast , just ask me :)
Cheers,
Marc B.
> John Loffink
> *From:* motm@yahoogroups.com [mailto:motm@yahoogroups.com] *On Behalf
> Of *eric f
> SPONSORED LINKS
> Label
> <http://groups.yahoo.com/gads?t=ms&k=Label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=6Ue5iYG1cB-4-PxKoePVpw>
> 	Cd music label
> <http://groups.yahoo.com/gads?t=ms&k=Cd+music+label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=HcQO9bFYletC1PmCSbcMNA>
> <http://groups.yahoo.com/gads?t=ms&k=Independent+music+label&w1=Label&w2=Cd+music+label&w3=Independent+music+label&c=3&s=60&.sig=4zI39fYigTJ8RURahZcwuw>
> YAHOO! GROUPS LINKS
>     *  Visit your group "motm <http://groups.yahoo.com/group/motm>" on
>       the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
