Power Question -- Adding +5v
2006-01-09 by Tkacs, Ken
Would someone on the list be so kind as to check my thinking? The only thing about my modular that’s a real gray area for me is the power supply portion. I’m no engineer, and the fact that the voltages involved are dangerous, coupled with the fact that I could burn out my modules, means that I cringe in terror whenever I need to work on the power supply.
But with the MOTM-650 around the corner, I guess it’s time to start thinking about adding that +5v rail to the cabinets.
I have the new MOTM power distribution board on order, the one with the new 6-pin connectors (http://www.synthtech.com/images/m990large.jpg). And I have some +5v PowerOne supplies on hand. I’m thinking that I would wire one in the following way… someone please yell if I’m about to do something rampantly idiotic.
- The AC power comes into the cabinet.
- Split it so that it goes to both “center pins” of a front panel DPDT switch.
- From there, both the +/-15v and 5v supplies are wired up independently, but the two chassis frames are bolted together (someone a while ago indicated that multiple power supplies in a system should have their frames electrically connected).
- Run lines (12 gauge wire) to the power distribution board from each supply to the appropriate screw terminals on the distro board.
Thanks in advance for any life- and system-saving advice!
Ken Tkacs
