Yes, Virginia, there is a LFO!
1999-11-29 by Paul Schreiber
Completed MOTM-320 pix at
www.synthtech.com/demo
as well as the MP3 demos of the JH/PS VC'd 12-stage phaser!
Re: Yes, Virginia, there is a LFO!
1999-11-29 by JWBarlow@xxx.xxx
In a message dated 11/28/99 5:13:25 PM, synth1@... writes:
OK, I'll bite. Why the tempco with the (presumably) non-matched pair of
transistors?
JB
Sorry, going to have to ponder more!
Yes, it is a tempco, and yes, it is in contact with 2 transistors.
Think, Grasshopper...........
To: <motm@onelist.com>
Sent: Sunday, November 28, 1999 11:19 PM
Subject: Re: [motm] Yes, Virginia, there is a LFO!
> From: JWBarlow@...
> transistors?
> JB
In a message dated 11/28/99 10:38:39 PM, synth1@... writes:
I think they may come pre-matched -- though that seems like a lot of work!
1999-11-29 by J. Larry Hendry
Temp stabilization of the osc (similar to the 300).
Other grass eatin' stooge.
LH
> From: Paul Schreiber <synth1@...>
> To: motm@onelist.com
> Date: Sunday, November 28, 1999 11:39 PM
> Paul S.
> From: <JWBarlow@...>
> > From: JWBarlow@...
> > transistors?
> > JB
1999-11-29 by Elhardt@xxx.xxx
Now that I see the back of the LFO and can see that it uses a dual color LED
with only two leads, I can't understand that $5.40 cost for LED and cable
assembly.  I would like to think Paul has wisely scanned catalogs and knows
what's available, but I noticed awhile back that Mouser has virtually the
same thing for a lot less money.  Pre-wired LED cable connection + lens + LED
would cost closer to $2.  However a dual color LED as a bypass or active
indicator on the VC Lag module is somewhat overkill anyway.
-Elhardt
1999-11-29 by The Old Crow
> assembly.
  There is also the polarity-reversing LED drive circuit to consider.
Granted, a 74LS00 will suffice, or some comparator/opamp output that
slopes between + and - wrt gnd, but it is an added cost.  Then there is
the circuit that interfaces the LED drive to the LFO itself.  It might be
trivial or it might be a bit more complicated--need to see the schem.
  I'm curious as to what the LED jumper row is for.
  I noticed a tempco on some differential pair.  Guess that is needed to
make those 10-minute cycles stay 10 minutes. :)
  --Crow
