Re: Mixer again
Re: Mixer again
1999-11-28 by Paul Schreiber
> Well, I hate to open this can of worms (mixer) again, BUT, it always
> generates some interesting and informative discussion.  Has anyone else
> checked out the Blacet site lately?  I thought his mixer was certainly
> thought provoking.  Seems that each input has gain both directions
> apparently with 180 degree phase reversal in one direction of the knob.
> So, looks like the mixer kind of doubles as a inverting attenuator / maybe
> with gain.
Corect, but being the clever folks we are would rather "build-in" this
feature
into each module. :)
> Anyway, I can see the advantage and handiness of having the inverter
> (separate).  However, I wonder how / why one might choose to invert the
> phase of one of the signals being input to a mixer.  The only thing that
> comes to mind is the cancellation that could be achieved between the
common
> parts of two signals.  Some of you guys enlighten me please.
99% it's for CVs, not audio. LFOs, for example. Inverted audio has no
meaning unless you
are trying to cancel out something (like a phaser! :)  )
> And what is the scoop with the "bias" control?  When I think of bias, I
> think of setting the mid point of the range where the signal rides on the
> input of an amplifier.  Back in my old tube days, the correct bias would
> assure that you were operating on the linear portion (or not, if that was
> your choice) of the tube's characteristic (input voltage to output
> current).  Seems like, on solid state, biasing off a center desirable
point
> would just result in ugly distortion.  What am I missing here?
It's a DC offset, again for CVs.
Mixer again
1999-11-28 by J. Larry Hendry
with gain.
comes to mind is the cancellation that could be achieved between the common
current).  Seems like, on solid state, biasing off a center desirable point
Well, I am not promoting the Blacet product here on the MOTM list, but
since many MOTM modules are centered around the "best" of some other good
designs, it seems appropriate to bring up what is at least a new feature on
a mixer to me.
Larry Hendry
Re: Mixer again
1999-11-28 by JWBarlow@xxx.xxx
In a message dated 11/28/99 12:29:45 PM, synth1@... writes:
>meaning unless you
This is probably why many (most?) modulars have two distinct types of mixers
-- plus the fact that some components are better suited for audio and some
for DC. But this also brings up a question I've had about canceling out audio
signals. I was thinking of adding some inverting attenuating inputs to some
DIY VCFs I've got (since they only use half of a dual op amp for the basic
inverting mixer they currently have -- a waste of 20 cents!).
I thought this may in fact be useful (with one big caveat) for subtracting
out harmonics in complex waves (like subtracting out a triangle from a
sawtooth wave), BUT (the caveat) one would have to add the fundamental since
that would be subtracted out entirely. I'm wondering if anyone has tried
this, or sees it as being useful? I have tried some initial experiments with
this, and have found that using (from one VCO) a SINE and inverted TRI (or
SQUARE) and an in phase SQUARE (or SAW), sounds better to me than using the
in phase TRI (or SQUARE). I really like the sound and wonder what others
think.
JB
Re: Mixer again
1999-11-29 by J. Larry Hendry
> rather "build-in" this feature into each module. :)
Being the clever consumer I am (hey I subscriber to MOTM didn't I?), I
would rather see such features "built in."
Of course.  I still have a hard time not thinking audio when I think mixer.
 Duh !!
Sure !! (same stupid look on my face as before).
Thanks Paul.  All that should have been obvious to me, but I keep
forgetting to put my "modular" brain in gear.  Your explanations do help me
appreciate the Blacet design even more (well, from looking at the picture).
 Unfortunately, I guess I will be once again trying to drive up the
features / prices of the MOTM mixer when we get to that (or maybe that
accompanying reversing attenuator).
Larry (Stooge wanting something with an inverter) Hendry
