Tire kicking on the S&H module
2005-12-31 by Paul Schreiber
a) I can design a version that is good enough for sampling noise (not keyboard voltages). I can still add quantizing to the 88-note scale, but the pitches will be "not perfect", but *very close*, say within +-1.5mv. The cost of the ADC/DAC chips, assuming 6 outputs per Richard's suggestion, is around $26. This is a 12-bit +-4LSB system (worse case). b) Or, I can do a 14-bit, +-1LSB INL system (good enough to 'hold pitch' for quantizing). The ADC/DACs needed makes the cost jumps to about $56. Adding the 0.1% resistors, proper low drift op amps, etc means a end-user price delta of $100. So, the quest is: is it worth $100 to get that 14-bit accuracy? Or, will most folks just sample the noise and save the $100? Paul S.
