FW: [motm] Interest in a MOTM-102 module?
2005-12-29 by Tkacs, Ken
I'm interested!
-----Original Message----- Thinking of a 1U wide, new noise/S&H module. Bad news: not a full kit, the pcb would be pre-soldered (teeny SMT parts). Still have to wire it up, though :) Good news: check these features! a) White/Pink out, digitally generated (Pink is analog filtered). b) the S&H is a cascaded, 4-channel "shift register" type with *infinite* hold time/zero droop (it's 12-bit digitized). There is a switch to either be 'Normal' (each int/ext clock samples the Input and passes it to the 4 outputs at once) or 'Shift' (each clock shifts the previous stage down to the next stage, and In always goes to Out #1). Like I said, not a full kit but a nifty module. And same price as current '101 kit. Discuss. Paul S.
