More uses for voltage controlled EGs
1999-03-15 by Dave Bradley
> From: "J. Larry Hendry" <jlarryh@...>Larry,
> > One use is to have the keyboard pitch voltage attenuated and applied
> directly
> > or inversely to the attack of an EG. Thus higher notes on the keyboard
> have
> > shorter or longer attacks than the lower registers.
> Thomas, You imagination is indeed bigger than MY budget <g>. But,
> seriously, thatnks for the thoughts on voltage controlled EGs. I am
> getting a lot of good ideas from those of you more experienced with
> modular. I mean, why even have a modular if you are just going to make
> "conventional " hook-ups.
> Larry H.
This is actually a very common use of VC on envelopes. So much so, that many
preset synths, analog or not, have this built in.
The other very common thing to do with VC is to control attack and release
times with keyboard velocity. My Chroma allows me to control attack time
with keydown velocity, and release time with keyup velocity. It makes for
some very expressive string patches, provided you master the keyboard
technique.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
