RE: [motm] Digest Number 2584
2005-12-10 by rdrake
Cynthia, on the order page, "status" is blank. if i place an order now, when will the module be delivered? bbob drake
>>cynthia.webster@... 12/08/05 12:50 PM >>>
>>Announcing...
>>The revolutionary new ~Zeroscillator~ FM VCO from
>Cynthia.
>>Available now in a variety of popular modular
>synthesizer formats!
>>(Yes, you read that right!)
>>http://www.cyndustries.com/
>>***** PRESS RELEASE 12/08/05 *****
>>They said it couldn't be done... but Team Cynthia
>went and figured it
>>out anyway!
>>Cyndustries.Com announces
>>The Amazing New Zeroscillator!
>>A Liquid Smooth All Analog Through-Zero FM
>Oscillator for Modular
>>Synthesizers
>>For the first time traditional digital FM
>synthesis is possible in an
>>all analog signal path.
>>Features Include:
>>Through-zero Linear FM Operation. AC & DC Linear
>FM Inputs with
>>4-Quadrant Dynamic Depth VCA. Separate Outputs
>for All Traditional
>>Waveforms.
>>Voltage Controlled Bi-Phasic Waveform Morphing in
>Four-Phase Quadrature.
>>Variable Synch. Precision Ten-Turn Tuning Knob
>>Switchable Linear Bias Modulation Depth and
>Polarity LEDs.
>>Unique Time Reversal Input!
>>What does all this mean? It means incredibly rich
>and alive sonic
>>textures are now available to you!
>>It means that brass, woodwinds, percussion and
>exotic electronic mayhem
>>are just a knob-twist away without need of
>filtering or other spectral
>>post-processing!
>>It means a whole new, exciting way of synthesizing
>sound on your modular!
>>Advanced engineering and the very latest in exotic
>semiconductors enable
>>the amazing Zeroscillator to create classic
>(digital) Linear FM
>>Synthesis on your modular with reliable,
>all-analog ("Look Ma, no
>>aliasing!") circuitry.
>>Physically, the Zeroscillator's design and build
>quality are
>>stratospheric. The finest components are employed
>using high-quality
>>4-layer circuit boards, NKK Switches and
>Switchcraft connectors. All
>>chips are in military-grade type gold sockets, and
>gold connectors are
>>used internally for years of trouble-free
>maintainance.
>>Sonically, Zeroscillators produce crystaline FM
>textures without the
>>assorted noises and grit of digital.
>Zeroscillators increase the
>>sophistication of your music because each use is a
>delightful journey
>>into undiscovered, exciting new dimensions!
>> Learn for yourself what the "Through-Zero" &
>"Dynamic Linear FM" buzz
>>is all about using actual analog synthesizers.
>Sieze this opportunity
>>to invigorate your music with this breakthrough in
>electronic
>>technology by equipping yourself with exciting
>new Zeroscillators today!
>>- 30 -
