Re: [Doepfer_a100] The Amazing New Zeroscillator!
2005-12-09 by Cynthia Webster
Bryan E Cornell wrote: >Well, through the magic of cutting and pasting images in photoshop, I've come to the conclusion that this new module is 36HP in Eurorack format. > >Bryan > > Hi Bryan! Yes, you are correct 36HP is the width, with slotted screw-holes for flexibility in mounting. The Euro Format Zeroscillator is the only 12 Volt version and comes with either a Doepfer or Analogue Systems type of Power Connector. Similarly, the MOTM version comes with an MOTM compatible power connector, and the Synthesizers Dotcom version comes with the Arrick power connector, and um, the Modcan/Cynthia version comes with a Modcan power connector. At one point we considered a small hamster and an exercise wheel, but this proved to be problematic as the hamster can't quite run quickly enough in order to generate the quadrature. Thanks for your interest! Cynthia http://www.cyndustries.com/
>>>>cynthia.webster@... 12/08/05 12:50 PM >>>
>Announcing...
>The revolutionary new ~Zeroscillator~ FM VCO from Cynthia.
>Available now in a variety of popular modular synthesizer formats!
>(Yes, you read that right!)
>***** PRESS RELEASE 12/08/05 *****
>They said it couldn't be done... but Team Cynthia went and figured it
>out anyway!
>Cyndustries.Com announces
>A Liquid Smooth All Analog Through-Zero FM Oscillator for Modular
>Synthesizers
>For the first time traditional digital FM synthesis is possible in an
>all analog signal path.
>Features Include:
>Through-zero Linear FM Operation. AC & DC Linear FM Inputs with
>4-Quadrant Dynamic Depth VCA. Separate Outputs for All Traditional
>Waveforms.
>Voltage Controlled Bi-Phasic Waveform Morphing in Four-Phase Quadrature.
>Variable Synch. Precision Ten-Turn Tuning Knob
>Switchable Linear Bias Modulation Depth and Polarity LEDs.
>Unique Time Reversal Input!
>What does all this mean? It means incredibly rich and alive sonic
>textures are now available to you!
>It means that brass, woodwinds, percussion and exotic electronic mayhem
>are just a knob-twist away without need of filtering or other spectral
>post-processing!
>It means a whole new, exciting way of synthesizing sound on your modular!
>Advanced engineering and the very latest in exotic semiconductors enable
>the amazing Zeroscillator to create classic (digital) Linear FM
>Synthesis on your modular with reliable, all-analog ("Look Ma, no
>aliasing!") circuitry.
>Physically, the Zeroscillator's design and build quality are
>stratospheric. The finest components are employed using high-quality
>4-layer circuit boards, NKK Switches and Switchcraft connectors. All
>chips are in military-grade type gold sockets, and gold connectors are
>used internally for years of trouble-free maintainance.
>Sonically, Zeroscillators produce crystaline FM textures without the
>assorted noises and grit of digital. Zeroscillators increase the
>sophistication of your music because each use is a delightful journey
>into undiscovered, exciting new dimensions!
> Learn for yourself what the "Through-Zero" & "Dynamic Linear FM" buzz
>is all about using actual analog synthesizers. Sieze this opportunity
>to invigorate your music with this breakthrough in electronic
>technology by equipping yourself with exciting new Zeroscillators today!
>- 30 -
>Join the new Cyndustries List at Yahoo!
>http://launch.groups.yahoo.com/group/The_Cyndustries_List/
>SPONSORED LINKS
>A100 Modular system Synthesizer Electronic payment Electronic test equipment Guitar synthesizer
>YAHOO! GROUPS LINKS
> Visit your group "Doepfer_a100" on the web.
> Doepfer_a100-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
