another cabinet bottom option Was: 1U high * * *
1999-11-24 by J. Larry Hendry
Well, since it seems that all are making the bottom of their "cabinets" different, I will throw up an idea that I am thinking pretty seriously about. Like someone else said in this long thread, I know I will have some rack gear used with my MOTM. So, I decided to have either a separate 5U high X 24U cabinet on the bottom of my slant cabinet, OR make my main slant cabinet 15U high (plus magic bus of course). The bottom 5 units would be set up to house either MOTM format or rack mount. If you examine the 24 U width we have been discussing, it will hold 2 wide 19" rack units with a 2U MOTM panel square in the middle for multiples, switches, or otherwise bringing rear stuff to the front through jacks. This would offer up 10 standard rack width 1U high spaces for whatever. And, since most of us already have some of Paul's rack rails, once or both sides of the 19" space could be converted to 5U standard MOTM space. My personal opinion is that I will have 5 or less 1U modules (MIDI2CV, EQ, vocoder, effects unit, Paul's latest craze), and the other side will have 10U of standard MOTM modules. So, that format lets you mix and match. A little imagination lets you figure out how to match the face plate depth. And, if I ever exceed the 5 1U spaces I have set aside, I can move into the other half. The only disadvantage of this set up is that if you fill the whole thing up with MOTM 5U height you only get 22U instead of 24U of useable space because you would have 4 "dress up" end caps if you had rack rail conversions on both side. One other one thought I had when I was considering making this rack wood cabinet separate (matching of course) that my MOTM slant cabinet would sit on was actually making two 19" cabinets that would sit side by side. The could house 10U MOTM or 5 1U rack. By having two cabinets side by side, the stuff in them could be gigged out easily without the remainder of the MOTM system in case the effects or whatever were something you would otherwise use. I do have ONE serious request Paul. If these things are to be designed to use with MOTM or external signals, can we please have a switch to select from low and high (MOTM) level signals so we don't have to make the "resistor" decision. We might want to use it both ways. And if you make it where a preamp has to be used for line levels only you may exclude some of that other market. Larry (cabinet crazy with options) Hendry
From: "Tkacs, Ken" <Ken.Tkacs@...> My own preference is for 5u "major" modules and 3u high "minor" modules, but I'm not pushing the 3u idea on anyone. I'm building a series of cabinets that are 13u high to house two rows of 10u MOTM gear and then a 3u "utility" section along the bottom for multiples, passive filters, a coupler panel, adapters, CV mixers, etc. Pretty much the Moog IIIp look. From: "Dave Bradley" <daveb@...> Consider this: I'm doing 2U high "minor modules" on bottom (Moog IIIc look) instead of 3U high, that way I can just buy a 5U x 2U blank MOTM panel and turn it on its side. You could buy 3U wide panels from Paul and do the same. You may end up cutting one short at the end if it doesn't come out a whole multiple of your cab width.
