OT: a most common RAM backup battery for a Jupiter 8?
2005-10-26 by Eric Frampton
Hi all,
I realize this is a bit off-topic, but I figured with the number of
engineers here someone might be able to help.
I'm (still) reviving a Jupiter 8. The backup battery is an obsolete
Panasonic size, a 1/2A. It's a lithium, and specs 3V at 650 mAh.
I don't want to go digging for this obsolete battery size ever again
in the future, and I'd like to find a modern equivalent with a
similar rating that, preferably, I could find a PCB-mount plastic
holder for (so I don't ever have to take it apart again to resolder a
new cell). Is there a "most common" 3 or 3.6V lithium that's in use
now that might fit the bill?
FWIW, the PC board solder holes are 25.5mm apart. I've got lots of
room in every other dimension to play with.
Thanks in advance,
Eric
Re: OT: a most common RAM backup battery for a Jupiter 8?
2005-10-26 by gregorykjar
Hi
I don´t know the excact Jupiter battery, but lithium 3 V are very
common batteries today. They are about half length of an AA an a
little bit thicker. I work with film sound and in microports from
Audio Limited you´ve got 3 of these batteries in the receivers.
So on a big film setup we´re using lots of these. You can try some
film equpiment rental company or maybe a store that sells camera
ascessories.
greetings
Gregory
--- In motm@yahoogroups.com, Eric Frampton <eric@e...> wrote:
> Hi all,
of
obsolete
again
resolder a
use
of
> Thanks in advance,
> Eric
