More MOTM-650 pix
More MOTM-650 pix
2005-10-13 by Paul Schreiber
Here is the prototype MOTM-650 MIDI-CV ready for it's debut in Oakland on
Sunday. The prototype sheet meat has a few glitches (some me, some the
fabricator) but all in all it looks great. The ribbon cable vendor skewed one of
the connectors, so you will notice a 'tilt' in the MIDI board. But, hey, it *all
works*. Let's see if I can get it past the X-Ray machine at the airport without
a full cavity body search. I'm going to mail it back home for the return trip.
After a 2 1/2 year wait, it almost ready to ship........
www.synthtech.com/pix/m650_front.jpg
www.synthtech.com/pix/m650_side.jpg
www.synthtech.com/pix/m650_rear.jpg
Re: [motm] More MOTM-650 pix
2005-10-13 by mcb, inc.
Never use sheet meat.  Unless you can get the biltong variety, it's
just going to flex and flex...
(Seriously, glad to see the Midi thru.  Was worried about that.)
m
Monty Brandenberg
2005-10-13 by jwbarlow@aol.com
In a message dated 10/12/2005 10:00:41 P.M. Pacific Daylight Time,
synth1@... writes:
Well the module looks good, but I will kind of miss the old black  panel with
white graphics. I guess the hand drawn ink labeling gives it a more  diy
look, eh!?
<snicker>
JB
That is how Larry & I referred to 'sheet metal' :)
Where??!?  The 2 jacks on the front are IN and OUT. There will be a set of
pcb pads to solder a MIDI jack to make a THRU on the back.
This is the only DIY soldering needed :)
white graphics. I guess the hand drawn ink labeling gives it a more diy look,
eh!?
I'm going for the Zvex pedal look next:
http://www.zvex.com/effects.html
2005-10-13 by Robert van der Kamp
Wow, that's a LOT of stuff in there! Congrats!
Will you have the video of the body search on the site? ;)
- Robert
On Thursday 13 October 2005 07:06, Paul Schreiber wrote:
> Where??!? \ufffdThe 2 jacks on the front are IN and OUT. There
> will be a set of pcb pads to solder a MIDI jack to make a
> THRU on the back.
Will there be an option to have a MIDI IN socket placed on
the back of the module, Paul?
- Robert
Re: More MOTM-650 pix
2005-10-13 by crmatt99
I guess we are all still guessing on the color of the buttons, hot pink maybe. Seriously this
looks great I'm sure many of us can't wait. Is a soldering "gun" also a bad idea at an
airport?
> eh!?
> Paul S.
2005-10-13 by Mike Marsh
Wow!  Cool! I love the DIY look of the panel. Can we still get it in
black, though?
Oakland on
skewed one of
hey, it *all
airport without
return trip.
> Paul S.
2005-10-13 by strohs56k
> Oakland on Sunday. The prototype sheet meat has a few glitches
> (some me, some the fabricator) but all in all it looks great...
cool!
I wonder if the MIDI in jack would look better centered between
connector column 1 and 2 (and the buttons above) much as the MIDI out
jack is centered between connector column 3 and 4?  Seems "off grid"
where its at now (not quite aligned to the first column of 1/4" jacks.)
Once the panel is black it will probably be less noticeable but theres
my design input :)
seth
Re: [motm] Re: More MOTM-650 pix
2005-10-14 by Paul Schreiber
> my design input :)
It has to be this way in order to fit.
There is a LOT going on behind the panels, trust me.
