Mounting MOTM power supply in .Com cabinet?
RE: [motm] Mounting MOTM power supply in .Com cabinet?
2005-10-04 by J. Larry Hendry
The MOTM power supplies (either 900 or 950) come mounted on a panel
measuring approximately 8.75" tall and 5.25" inches wide.  You can mount
that in the front or back of your dot com 22 space cabinet.  The dot com
cabinet has a 8.75" tall by 8.5 inch wide hole in the back for power supply
mounting.  The MOTM supply will fit with room left over.  You can screw it
right to the wood with the same kind of wood screws used to attach your dot
com modules.  You will need to drill pilot holes to reduce the risk of
splitting the wood.
If you want the flexibility of using machine screws for mounting MOTM
products in dot com cabinets, I sell some flat rails which make moving stuff
around very easy.  Here is some info:
http://www.wiseguysynth.com/larry/flatrail/flatrail.htm
and
http://www.wiseguysynth.com/larry/cabinet/dotcom/dotcom.htm
Drop me a note if you have questions
Stooge Larry
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com]On Behalf Of
brownchonald
Sent: Tuesday, October 04, 2005 4:11 PM
To: motm@yahoogroups.com
Subject: [motm] Mounting MOTM power supply in .Com cabinet?
I was curious how one would go about installing a MOTM power supply in
a synthesizers.com 22 space cabinet.
Cole
Re: [motm] Mounting MOTM power supply in .Com cabinet?
2005-10-05 by Richard Brewster
I have several of these.  As Larry said you can mount the assembled MOTM
power supply to the front or to back of the case.  If you choose the
front, it is of course the easiest option, but you lose 3U of module
space <shudders>.  If you choose the back, you probably want to mount it
on the opposite end from the opening made for this purpose in the
cabinet.  I did it this way initially.
http://www.wiseguysynth.com/larry/users/richard1/cabinet/dotComCabinet.htm
A drawback to this approach is that with the power supply protruding its
4-inch height, you can mount only shallow modules in front of it.  I
later came up with the following alternative.
I unmounted both the supply and the power distribution board from the
MOTM panel.  The power supply is rotated so that it is parallel to the
long dimension of the cabinet now and mounted to the wood so that its
smallest dimension, about 2.5 inches, takes up space behind the panel
and you can mount deeper modules in front of it.   I used an angle
bracket on the end where the hole isn't easy to reach because of the
transformer.  The AC wiring is not changed.  The power distribution
board is mounted near the back of the cabinet more toward the center.
You can upgrade to a MOTM-960 or 990 distribution board.  I used some
16-gauge wire to connect up the 960 to the supply.  I will take some
photos of this.  I'm about to do a bit of rewiring to upgrade a cabinet
to the HBB15-1.5-A Power One unit.  A MOTM-900 might provide sufficient
power for the 26U cabinet, if all MOTM.   But I cramed as many
submodules behind each panel as I could, and I have some non-MOTM
modules that consume more power than the MOTM average.  So my power
requirements are a bit more.
By the way, I very highly recommend Larry Hendry's mounting rails and
Synthesis Technology logo end piece for this cabinet.  I got pretty good
at doing it by the time the fourth cabinet was done!  It is really not
difficult.  I am always rearranging modules as I add more cabinets, and
the rails make it a snap.
-Richard Brewster
>Cole
>Yahoo! Groups Links
