Electrolytic Cap Placement & Solder
1999-11-21 by Elhardt@xxx.xxx
I'm stuffing compenents in all my boards for the first pass solder/wash.  I
normally mount electrolytic capacitors firmly up against the PCB.  After
reading about the problems of organic flux residue, I am wondering how I am
going to clean under under them.  Does it matter if I can't clean under them?
 Or do I need to keep a centimeter or so space, so I can clean?  Thanks for
any help.
BTW, this business of having to wash boards within 2 hours of soldering is
seriously screwing up my assembly line building techniques.  Is the only
reason we are not using good old rosin core 63/37 solder because it leaves
unsightly flux marks?
-Elhardt
Re: Electrolytic Cap Placement & Solder
1999-11-21 by Paul Schreiber
I
am
them?
Actually, the hole spacing is about 0.025 *wider* then 'spec' to make the
caps "stand up"
off the pcb about 1/32" so the water will flow under there. Note the "yellow
box caps"
have small cutouts for this purpose.
> Is the only  reason we are not using good old rosin core 63/37 solder
because it leaves
There are two reasons MOTM does not use rosin core solder (in fact, no one
has used rosin-core solder
*in mass production* since about 1990).
#1 - rosin is designed to *attract moisture* (think of the rosin bag in
baseball, and in gymnastics). Attracting
moisture in *NOT* what we want in synths! Especially VCOs.
#2 - in order to *remove* the rosin off the boards, you need *horribly
messy* chemicals. Freon was the older
choice. There are spray cans of non-CFC rosin flux remover, but my
experience is that this makes a huge
mess because all you do is dissolve the flux and coat the whole pcb with it!
In production lines in the '70s/'80s
there were massive, high-power water jets that 'scrubbed' the flux off with
150 psi water nozzels after a good old Freon
bath (the boards were actually immersed in liquid Freon).
Today, *all* soldering is using "No Clean" flux.
So, a fair question is :"Why not use No Clean everywhere?"
The answer is that I felt that No Clean is harder to solder, and that
organic *still* has the best overall
joint construction. The only reason No Clean replaced organic is that the
manufacturers saved millions
of dollars on water bills (and floor space!).
(Paul Schreiber) writes:
caps "stand up" off the pcb about 1/32" so the water will flow under there.
Note the "yellow box caps" have small cutouts for this purpose.<<
Thanks for the info.  Since I haven't yet soldered with organic flux solder,
I didn't know the residue came off so easily.  I thought it required some
persistent scrubbing.
As far as solder goes, I forgot about the moisture problem, and I had no
intention of cleaning the rosin off.  I don't like the toothpaste consistancy
of no-clean, but maybe I should learn to like it.  It could save me a good
chunk of time.  Or perhaps it's time for a wave solder machine.
-Elhardt
Organic flux is actually a mild version of vinegar. I just use warm water
and barely scrub the board for maybe 5 seconds per side.
To: <motm@onelist.com>
Sent: Saturday, November 20, 1999 8:59 PM
Subject: Re: [motm] Electrolytic Cap Placement & Solder
> From: Elhardt@...
there.
solder,
consistancy
> -Elhardt
Kester Flux #331, 0.020 diameter. I buy it from Allied.
Sent: Saturday, November 20, 1999 11:31 PM
> From: "J. Larry Hendry" <jlarryh@...>
> Speaking of solder.....  Paul what solder do you buy for "organic?"  Since
> I know you are Mr. Mouser, I bet you have a Mouser page number or part
> number for it.
> Thanks,
> LH
> > From: "Paul Schreiber" <synth1@...>
> one
> it!
> with
> > Paul S.
1999-11-21 by J. Larry Hendry
number for it.
LH
one
it!
with
> Paul S.
1999-11-21 by Christopher Jeris
Laugh at me, but I did this -- a PAiA midi2cv8 was the first kit I built
after my first few MOTM modules, and it didn't come with solder.  I made
the mistake of buying rosin core (not yet understanding the differences
between solder types) and then had to get it all off.  First I tried to
use isopropanol moistened cotton balls.  Great, now I have bits of
rosin-sticky cotton fluff all over my pcb!  Finally I had to fill a pie
pan with the alcohol, dunk the board and scrub it with the trusty "Flux
Remover" toenail brush.  20 minutes each side, refilling when too much
alcohol evaporated ... and the board is _still_ sticky in places.  Sigh.
That's how I learned not to use rosin core on pcbs.
(Speaking of toenail implements, has anyone else tried a big sturdy
toenail clipper for snipping leads?  I may be crazy but I think it works
_much_ better than diagonal cutters.)
peace,
Chris Jeris
1999-11-23 by Hugo Haesaert
Hi All !
That no-clean solder "wet's" a bit harder, i think it has to do with
the flux used, but i've experienced no "tooth-paste" effects . This
with an unregulated iron .  Since a good week i'm using a kit-built
electronic soldering station, and get similar results to the organic
and rosin solder, with the temperature 20C higher .  At this temp the
organic and rosin solders splatter more .  That no clean solder still
leaves a deposit, but i gather that this is inoffensive .
Not all rosin solders are the same .  I still got some that resulted
in a brown molasses-like crust .  Here in europe it is almost
impossible to find anything else than rosin based solder in shops .
(But my stock of no-clean is growing ;-) )
Another thing is that double sided boards "take" more solder than
single sided .  Hence more flux remains .
Vinegar is acetic acid, afaik always liquid .  Probably still got
lung damage from the years passed poring over the infamous "stop-
bath" used in B-W chemical photography .  I believe nowadays citric
acid or potassium-bromide is used here .  Citric acid is available in
cristallline form, so could be used in solder .  But there are many
more compounds around .  It's anybody's guess what they are actually
using .  The smoke it gives off is no less irritating than the rosin
fumes, imo, but the smell is different :)
Freons are good products with the unfortunate property of destroying
the ozone layer .  They are rightly banned from most applications,
and production has stopped afaik .  The airliner industry still uses
halon fire extinguishing systems, as they are still the best way to
put out a fire .  And they are not poisonous when inhaled .
Releasing massive amounts of co2, as normal for electrical fires, in
the confines of that pressurised cigar-tube is just not on :) . The
freons used here are religiously recuperated and recycled, at great
cost .  In the "cold" industry replacements are used that are similar
but less reactive .
I assemble my boards in 3 layers, depending on the height of the
components .  Recently i got an assembling frame that can hold the
board at 3 different depths (4 euro cards/MOTM boards at once, if
needed) . One closes a foam lined lid over the parts, flips over the
frame and the soldering fest can begin :)  No splaying of leads to
hold the components .  Still, i only solder one lead per component at
first, then inspect and adjust, then the rest of the pins .  Before
the frame i used a diy version of this procedure .
Haa, nothing like a vacation to write long emails :)  Off to the next
module .
Bye for now .
Keep 'em oscillating :)
Hugo
1999-11-24 by JWBarlow@xxx.xxx
In a message dated 11/21/99 10:16:27 AM, cjeris@... writes:
I used to use these, but had too many instances when I actually cut (broke?)
the joint off which I'd assumed was due to the clippers getting dull. Since
then, I just use those tiny diagonal cutters (which work great) but I often
think about getting those bent nose cutters designed for this purpose.
JB
Hey! How bad is to use the old Kester 44 without defluxing -- not MOTM but
general circuits (bad, not good, great)? The only time I've seen a problem is
around hot areas on boards (after a long time) where the flux has really
flowed around other components.
