Index last updated: 2026-03-31 13:59 UTC
Stupid question re power distro boards
2005-08-12 by Adam Schabtach
Sorry to annoy the list with a question primarily aimed at Paul, and forgive
me for not paying attention, but what's the current state of power
distribution boards? That is, what's the difference between a 960 and a 990,
which are currently available, and why would I want one vs. the other?
Thanks. Standing by with otherwise filled order form, credit card in hand.
--Adam
Re: [motm] Stupid question re power distro boards
2005-08-12 by Paul Schreiber
a) MOTM-960 has 4-pin connectors only (+-15V modules)
b) MOTM-990 has *both* 4-pin and 6-pin (added +5V for digital modules)
However, if you want a board shipped within the next 2 weeks, get a '990 because
I just shipped 27 MOTM-960s
and I'm making 25 more.
The order form doesn't add the postage because my JavaScript sucks. It's $5.
To: "'MOTM litserv'" <motm@yahoogroups.com>
Sent: Thursday, August 11, 2005 9:26 PM
Subject: [motm] Stupid question re power distro boards
> --Adam
2005-08-12 by Matthew Hiscock
You read my mind, Adam.
The 960 is also much larger capacity, though, isn't it?
> '990 because
> It's $5.
> Paul S.
> From: "Adam Schabtach" <adam@...>
>> forgive
>> a 990,
>> hand.
>> --Adam
>> Yahoo! Groups Links
_________________________________________________
+ Reviews for Xpander/365Mag: www.365mag.com +
+ and Exclaim magazine: www.exclaim.ca +
+ The Bootleg Sounds label: www.bootlegsounds.com +
2005-08-12 by Scott Juskiw
The 960 has 21 4-pin headers.
The 990 has 6 4-pin headers and 10 6-pin headers (16 headers total).
Both have screw terminals so you can attach more power cables if you need them.
PCB update, and say hello to MUUB
2005-08-13 by Scott Juskiw
I just wanted to let everyone know that the circuit boards I was
expecting in August have all arrived. This includes: TLN-156 Neural
Agonizer (spring reverb), DB-120 (add on to MOTM-120), and TLN-854
Sword of Kahless (ribbon controller). So everything is ready to be
shipped, details can be found here:
www.tellun.com/motm/diy/diy.html
New on the list of available PCBs is MUUB, the Multi-Use Universal
Buffer. MUUB is a general purpose PCB that can be used to create a
variety of op-amp based circuits for creating new modules, or adding
enhancements to existing modules. MUUB is another group effort by
Richard Brewster, Larry Hendry, and myself. MUUB comes in two sizes:
MUUB-2 contains one dual op-amp, MUUB-4 contains two dual op-amps.
When putting this together, I had a look through Jung's op-amp
cookbook and Craig Anderton's books and found well over two dozen
useful circuits that can be created using one or more MUUBs. I've
also brain stormed several new utility modules and enhancements to
MOTM modules that I'm planning to publish over the next few months
that use MUUBs. I will write this all up in the MUUB user guide,
someday, when I get a chance. And I'm sure that Larry and Richard are
also working on some interesting MUUB designs.
In the meantime, Stooge Larry suggested we have a circuit design
contest to build up a pool of MUUB circuits. I think this is a great
idea and I've put up the contest rules on my website (along with all
currently available MUUB documentation):
www.tellun.com/motm/diy/muub/muub.html
Anybody can enter, since there's only one judge (me), there shouldn't
be any collusion. I won't publish any of my own designs until after
the contest.
Scott J.
Re: [motm] PCB update, and say hello to MUUB
2005-08-13 by Greg Amann
The MUUB has arrived!
Any plans to rerelease the Veeblefetzer? Meters are cool, but also very handy.
the contest.
Scott J.
MOTM-650 poly-aftertouch? (think CS-80!)
2005-08-14 by Dino Leone
Will the MOTM-650 have polyphonic aftertouch
implemented? I just checked the description on Paul's
website, but it doesn't say anything... oh my, I fear
the worst!
Paul, if there's *any* way you could implement this,
so that the AUX1-4 could be assigned to respond to
poly aftertouch, please please!!! This would make this
MIDI-CV interface truely unique!
Here's my reasoning: I'm thinking CS-80: use 4
MOTM480, a masterkeyboard that can transmit polyphonic
aftertouch (see my list below) and moulate filter
cutoff on a per-note-basis. Oh what a wonderful idea
for us poor souls who never could get a real Yamaha
CS-80!
Again, please Paul, if there's any way you could
squeeze that into the 650...
Here's the list of synths I found that support and
transmit (only the MIDI ones..) polyphonic aftertouch:
- Yamaha CS60, 80
- Yamaha DX1
- Polymoog
- Ensoniq SQ80, TX10, VFX, SD, EPS, EPS-16+ up to
ASR-10
- Sequential Prophet T8
- Waldorf Q, XT
- Roland A-80 (the only Roland that supports it)
- Yamaha MOTIF series
With Best Wishes
Dino
Do You Yahoo!?
http://mail.yahoo.com
RE: [motm] PCB update, and say hello to MUUB
2005-08-15 by J. Larry Hendry
Huge thanks to Scott for taking on the MUUB project. This is something I
have wanted to do for a long time, but simply have zero time to consider
adding one more product to the Stooge line. The project has evolved since
my original desire to do it, mostly thanks to input from Richard Brewster
and Scott's hard work. The original idea belongs to Thomas Henry who many
years ago sold a small size dual op amp PCB he called the utility knife.
Sadly, these are no longer available. But, the MUUB-2 has all of that and
more. The MUUB-4 is just twice the fun.
When you need a small mixer, input or output buffer, reversing attenuator,
need to add or subtract gain, the little op amps often make the job very
easy. While it does not sound all that sexy, it really does clean up a lot
of modifications and make easy work of many common op amp circuits.
The design contest a cool idea. I thought Scott was the one that thought of
it. I have a very cool design that uses one each I know several of you will
be happy to see. I do plan to make it public but not to enter it in the
contest (no conflict of interest here). :-)
BTW, my original name was Multiple Use Utility Buffer, but it somehow
migrated in the process (or in my feeble memory). And MUUB is pronounced
like the "wrong" way to say pronounce "Moog."
Stooge Larry
the contest.
Scott J.
Re: [motm] MOTM-650 poly-aftertouch? (think CS-80!)
2005-08-17 by Paul Schreiber
> the worst!
It may be offered as a 'pay-per-view' upgrade. Not for the initial release.
2005-08-17 by Dino Leone
Pay-per-view? Wait a minute... you can't do this! ...
hmmm... or maybe you can. Damn ;-)
Dino (griping quitely with emperor Paul's decision
Do You Yahoo!?
2005-08-17 by Mike Estee
Yeah, I'm not thrilled with that either, but Paul's not a software
engineer and software engineers are 'spensive. Well, unless they get
excited about the problem on their own, but then you don't get much
control over the output ;)
I personally mind paying for bug fixes, but I've got no problem paying for
features. This is the camp I think most people fall into.
--mikes, a software engineer.
No one pays for bug fixes. But to add a feature maybe 3 people will ever use,
that's a different story :)
Re: MOTM-650 poly-aftertouch? (think CS-80!)
2005-08-17 by mate_stubb
Let's get the damn thing out already. I sold my Expressionist two
years ago in anticipation of this module.
Just my opinion,
Moe
http://hotrodmotm.com
