RE: Trim & Cabinets
1999-11-19 by Mark T
Hi All - Taking a break from my MCSE studies and saw the revisited TRIM issue. Its been a while since I've posted here. I was thinking about the same thing that Eric mentioned - removing the paint from the edges of the modules. The key issue would be to get a super clean edge and consistency among modules. My proposed solution would be to score a line with a razor through the paint then into the aluminum. The next step would be to use the "Binding Cutter Attachment" from Stewart McDonalds Guitar Supply. http://www.stewmac.com This gadget attaches to the end of a Dremel Moto-Tool, and has pre-set width and depths. There is a special bit that is used with it - kind of looks like an end mill. You would need to fashion a jig however to compensate for the excessive width and depth that the attachment is preset to. Another possibility would be the Dremel router attachment. I'm looking for some scrap aluminum that I can experiment with - I'll post results when finished. Regards, Mark
