Unsoldering parts - a useful tool to keep around
2005-08-06 by Richard Brewster
I wanted to replace several resistors on a PC board recently and needed
more than just solder wick. My old heated desoldering iron gave up the
ghost. I ran out to Radio Shack and found this solder sucker tool that
I hadn't noticed before.
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F009%5F007%5F004&product%5Fid=64%2D2098
You have to be fast, heating the joint then quickly placing the sucker
over it and pressing the release. It comes in handy for cleaning out
the holes after you have removed the old leads. With this tool, plus
some solder wick, you are equipped.
-Richard Brewster ("man of cheap tools")2005-08-06 by John Blacet
I typically use a solder sucker with the PCB in a holder so I can access
both sides of the board. I can use the iron on one side and the sucker
on the other.
You want to cant the sucker just a bit to avoid too much suction that
*may* suck the pad off the board. You also need to move the iron a bit
just before you push the sucker button. This allows air to blow through
the hole.
I precede all the above by cutting the part lead and removing what's
left on the board with a soldering iron and an odd flush cutter that has
a set of sharp edges. They look sort of like needle nose but the sharp
edges minimize heat transfer and are good at grabbing short bits of
component lead.
> <http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F009%5F007%5F004&product%5Fid=64%2D2098>
> YAHOO! GROUPS LINKS
> * Visit your group "motm <http://groups.yahoo.com/group/motm>" on
> the web.
> * To unsubscribe from this group, send an email to:
> motm-unsubscribe@yahoogroups.com
> <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
John Blacet
Blacet Research
http://www.blacet.com2005-08-06 by DJ Arago
Thought this might be useful to some people.
i have a little red solder sucker ball sort of thing from radioshack (for
about half the price, man o cheap tools). It works just as you've
described, but it's shaped differently. However I've found that sometimes I
just can't seem to get all the solder out. If I then add more solder
(purposely) it actually helps suck all the solder out in one shot.
Don\ufffdt just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/2005-08-09 by imorpheusl@aol.com
I've had one of these for years and have been very satisfied. I haven't even needed to replace the plastic tip or anything. It rocks ;P (as much a solder sucker can rock) -Chaz
To: MOTM List <motm@yahoogroups.com>
Sent: Sat, 06 Aug 2005 13:05:22 -0400
Subject: [motm] Unsoldering parts - a useful tool to keep around
------------------------ Yahoo! Groups Sponsor --------------------~-->
<FONT COLOR="#000099"><font face=arial size=-1><a href="</FONT><A
HREF="http://us.ard.yahoo.com/SIG=12hpdblbv/M=362335.6886442.7839733.3022183/D=grplch/S=1705032277:TM/Y=YAHOO/EXP=1123355075/A=2894366/R=0/SIG=138c78jl6/*http://www.networkforgood.org/topics/arts_culture/?source=YAHOO&cmpgn=GRP&RTP=http://groups.yahoo.com/"><B>Click
Here!</B></A><FONT COLOR="#000099">">What would our lives be like without music,
dance, and theater? Donate or volunteer in the arts today at Network for
Good</a>.</font></FONT>
Yahoo! Groups Links
