Possible MOTM-485 resistor tweak
2005-08-06 by Paul Schreiber
For those of you looking at building kits this weekend :) I am going to look at a *possible* resistor change to see if I can increase the resonance a bit, mainly for the LP mode. So, if you want to hold off until I finish (no later than tomorrow afternoon, will try to get it later tonight but today is pretty busy), then do so. I don't think the change will be that dramatic, and you will have to provide your own resistors (I'll try to give several possible values). Grumble....diode filters....mutter...... Paul S.
