I clued Larry H. in to some 12 ga. speaker cable from Carvin for this purpose. He
reports it is perfect. It comes with speak-ons on each end, cut it in half and attach
speak-ons to the cut ends. That will give you two 5 foot lines, which is probably as
long as you want to go with low voltage. Carvin's cat. # is SP10 for the 10 foot four
conductor cable, and you'll be ready for the coming +5 volt modules. Strangely
enough, their web site is carvin.com.
Mouser #s for the cable connectors is 568-NL4FC. Chassis mount connectors for the
cabinets is 568-NL4MP.
HTH
Q
--- In motm@yahoogroups.com, "Tkacs, Ken" <ken.tkacs@j...> wrote:
> I believe several people on this list are using Neutrik Speak-On
> connectors to bring power from a main cabinet to a satellite cabinet.
> Can any one tell me (or point to a web site) exactly what parts you are
> using, including what kind of cable is being used (or wire gauge or
> whatever) for the internal and external harnesses? Part numbers (Mouser,
> Newark, etc.) are always appreciated!
> Thanks in advance!
> KT
