Re: Ribbon Controller - Kurzweil Expressionmate
2005-07-30 by ivancu@aol.com
Index last updated: 2026-04-02 23:24 UTC
2005-07-30 by Greg Amann
I had bought an Expressionmate when they first came out and was turned
off by the fact that it output info as pure MIDI notes, so instead of a
continuous "portamento" it was a "glissando." Of course later I
realized that this is a function of MIDI, where it is designed around
discrete notes rather than continuous variable voltages.
Is there a way to get around this?
Ivan
2005-07-30 by Scott Juskiw
>I had bought an Expressionmate when they first came out and wasturned
>off by the fact that it output info as pure MIDI notes, so instead ofa
2005-07-31 by Dana Countryman
> Right, but how can you get it to control a MIDI synthesizer so as notHi Ivan --
> to play individual notes when sliding up and down the ribbon?
> Ivan>>
> -----Original Message-----
> From: Scott Juskiw <scott@t...>
> To: ivancu@a...; motm@yahoogroups.com
> Sent: Sat, 30 Jul 2005 10:07:51 -0600
> Subject: [motm] Re: Ribbon Controller - Kurzweil Expressionmate
> Check if the Expressionmate can do either of these:
> 1. Can it output a continuous controller message instead of note
> on/off?
> 2. Can it output note on/off with pitch bend?
> Either of these modes should be able to produce a reasonably smooth
> portamento from MIDI messages. The brand D ribbon controller supports
> both of these.
> turned
> a
2005-07-31 by djbrow54
2005-08-01 by Scott Juskiw
>not to play individual notes when sliding up and down the ribbon?
>Ivan
>From: Scott Juskiw <scott@...>
>To: ivancu@...; motm@yahoogroups.com
> 1. Can it output a continuous controller message instead of note on/off?
>supports both of these.
2005-08-02 by Mike Estee
> With the upcoming Stooge panel run, I thought it would be prudent toAlright, silly question
