24U or 26+U?
1999-11-18 by Eric S. Crawley
Folks, All the talk about 24U Moog-like cabinets has raised a few questions I've had. I want to add a cabinet to a modular Moog for MOTM modules. The height of the MOTM modules is the same as the Moog modules but of course the width is different. I'd like to get a cabinet that is the same external measurements as the Moog upper cabinets (48.25" wide). When I do the measurements, I get 26U and change of space. I see everyone talking about 24U cabinets which makes me think I'm doing something wrong. Am I not calculating the "slop" space correctly? Isn't 1U=1.75"? Of course, having the space for an extra 2U module is a good thing, right! Is anyone out there building a cabinet that is *exactly* the outside size of a Moog cabinet? How did you develop the dimensions? While I'm at it, is there any simple piece of trim that I can put between the MOTM modules that will match the look of the metal that shows between the Moog modules? I see the pictures of "Dave F's" system on the Synthtech site has different colored strips between the MOTM modules. What was used? Thanks, Eric
