Proximity Control (tm) - (was: Heat Guns)
1999-11-14 by Cary Roberts
>so if we're up for another MOTM record-breaker here's my addition: >i got a 1400W Black & Decker heat gun for \ufffd20 i can use it on either small >pieces of heatshrink or big looms thanks to its intuitive proximity control >(tm) >had to come up with some smart comment This reminds me of a post to rec.audio.pro back in '95, when the 'net was a nice place to be and void of spam and porn: ___________________________________________________________________ There are several such innovations to at B*se! One is Larger Driver Technology (tm). This extremely clever approach uses a single large driver to reproduce low bass instead of several small drivers! The "engineers" there have stumbled onto something known as The Free- Air Resonance (tm) of a loudspeaker. It seems that the lower it is, the greater capability for greater low end bandwidth. Also being developed is the use of Direct/Direct (tm) technology. This is the result of extremely advanced research into the bowels of acoustics, and the research has shown that more accuracy can be obtained by NOT USING EXTRA DRIVERS TO SIMULATE WIERD AND FUNKY REFLECTIONS! Those whizzes at B*se have found Better Sound Through Research by NOT SIMULATING REFLECTIONS CLAIMED TO BE THE SAME AS THOSE IN A CONCERT HALL! They have foregone "Acoustic Mass (tm)" in favor of "Acoustic Weight (tm)" in order to acknowlege the presence of the force of gravity. In short, we should see some mind-boggling and awesome advances in loudspeaker engineering soon. Prepare to bow low to The Most Respected Name in Audio! ____________________________________________________________________
