Op-Amps
Op-Amps
2005-06-05 by Greg Amann
Thanks for the dirt on the LEDs.
Next question:  I would like to collect a few Op-Amps to keep around
for DIY fiddling.  Any recommendations for the top 5 candidates to
keep in a well-stocked MOTM experimenters work bench?  A general
purpose Op-Amp to drive LEDs.  An audio preamp.  That kind of thing.
The TL072?
Thanks,  Greg
Re: [motm] Op-Amps
2005-06-05 by Paul Schreiber
All you need is 2 types:
TL072ACP - audio path
LT1013P - DC summers
both available from DigiKey
Re: Op-Amps
2005-06-05 by mate_stubb
Check out my parts source page:
http://www.hotrodmotm.com/parts_list.htm
Moe
> The TL072?
> Thanks,  Greg
Re: [motm] Op-Amps
2005-06-05 by Mark
Hmmm...   I agree with Paul's suggestions, but you asked for five ;)
I have a number of OP-275 that I use for audio -- very fast, low
noise, and high current.  I use the LT1013 for precision voltages,
but they are slow.  I have a bunch of SSM2135 that I use for
single-sided (9V battery audio applications) and you should have a
fast op-amp that can work single sided if you plan on building
stomp-boxes.  However, the op-amp I use the most, is the TL072 --
fine for summing non-critical voltages, inverting signals, creating
high-impedance inputs, driving LED's, and as an output amp for gates,
triggers, LFO's, envelopes, etc.  The fifth op-amp is the unusual
LM3900 "Norton" amplifier used in a number of different applications.
Since through-hole parts are becoming more difficult to find, some of
these might now be obsolete.
On 6/5/05, Greg Amann put forth:
>The TL072?
>Thanks,  Greg
