I have seen the future ...
2005-05-15 by Greg Amann
Here is the problem: I have seen the future and it involves LOTS of
modular synth bits.  And regardless of who I read aboot, they say they
have run out of space for their rig.  Also, the future includes +5V.
Really it does.
So here is the plan:  start nice and easy and get something up and
running at a reasonable cost, hopefully using parts that can be
cannibalised into larger designs in the future or sold off without
loosing all of their value.
So here is the question:  currently I own or have on order only
modules that require +/- 15V.  But I can tell that I will eventually
need +5V.  Is the following solution feasible?  Purchase a 5A Power
One +/- 15V linear supply now and add a small +5V supply at a later
date.  Assuming that I connect the secondary grounds, will this be
electrically adequate to power the inevitable MOTM MIDI-CV module
purchase?
PLL, BFG
Re: [motm] I have seen the future ...
2005-05-15 by Paul Schreiber
The Power One's with added +5V are cheaper than buying 2. Look at the CP-131
model, for example.
But, you can always add a +5V, 6A supply later. Just tied the grounds together
*at one point only*. A terminal block is good for this.
To: <motm@yahoogroups.com>
Sent: Sunday, May 15, 2005 6:49 AM
Subject: [motm] I have seen the future ...
> Really it does.
> purchase?
> PLL, BFG
While we're talking about power supplies...
2005-05-15 by ben vehorn
How difficult is it to switch an MOTM 900 over for 12v use? What would
this entail?
I'm running my MOTM stuff alongside my Modcan stuff on a giant 3A
Cyndustries supply now and want to use the 900 to add a few Doepfer
modules. Their cases/supplies are too expen$ive for me so I wanted to
build a case and put the 900 back in service.
Also, is there a master list of MOTM current draw per module anywhere I
could peruse?
Thanks.
---Ben
> CP-131
>  model, for example.
> together
>  Paul S.
Re: [motm] While we're talking about power supplies...
2005-05-15 by Gert Jalass
Hi Ben,
this can be done pretty straightforward - on the PCB (of the Power One) you can spot (the remains of) two jumpers (VW1 and VW2). "Re-install" them and the supply will provide +- 12V. You may need to adjust the two trimmers (labelled "-V ADJ" and "+V ADJ") to trim to the expected output voltage.
Gert
To: Sent: Sunday, May 15, 2005 4:17 PM
Subject: [motm] While we're talking about power supplies...
How difficult is it to switch an MOTM 900 over for 12v use? What would this entail?
I'm running my MOTM stuff alongside my Modcan stuff on a giant 3A Cyndustries supply now and want to use the 900 to add a few Doepfer modules. Their cases/supplies are too expen$ive for me so I wanted to build a case and put the 900 back in service.
Also, is there a master list of MOTM current draw per module anywhere I could peruse?
Thanks.
---Ben
model, for example.
2005-05-15 by Scott Juskiw
>purchase?
Yes, I have done this. I have standard issue MOTM-900 power supplies
in each of my cabinets. In one cabinet I added an additional +5V
Power One supply along with the MOTM-990 power distribution board.
The MOTM-900 supplies +/- 15V and analog GND to the 990, and the
other supplies the +5V and digital GND to the 990. I have been
meaning to document this on my website but haven't had time. All I've
got is this one picture showing how it all hooks up:
http://www.tellun.com/two4one.jpg
The distribution board on the MOTM-900 has been replaced by a piece
of plexiglass that holds a terminal strip and two additional fuses.
You have to fuse each power supply separately, plus there's a
redundant third fuse in the power on/off switch. Also, you have to
connect the two grounds of the power supplies together to maintain a
"star" ground.
2005-05-16 by The Old Crow
...and it has now gone from one to two children.  Emily Claire Rider
decided to arrive a week early, born May 12th at 8:30AM.
  I might get to solder stuff again in...what...2009?
Crow
2005-05-16 by Larry David
Congratulations - when you are old I doubt you will look back and say,
"Dangnabit!  If I hadn't been bothered by my family so much, I would
have had more time to solder!"  :)
Larry (father of 6)
> Crow
Re: While we're talking about power supplies...
2005-05-23 by benvehorn
Hi Gert/list,
I'm about to do this right now.
I found the VW1 and VW2 pairs of stubs.
I can just re-connect each one with jumper wire, correct?
I don't need a resistor or anything?
Thanks.
---Ben
--- In motm@yahoogroups.com, "Gert Jalass" <synth@g...> wrote:
> Hi Ben,
> Gert
>   ----- Original Message -----
>   From: ben vehorn
Re: [motm] Re: While we're talking about power supplies...
2005-05-24 by ben vehorn
Nevermind, I got it.
Thanks.
On May 23, 2005, at 6:52 PM, benvehorn wrote:
> Hi Gert/list,
>  Thanks.
>  ---Ben
