MOTM-320 Rate frequency output
2005-05-14 by Don Ojeman
Hi Paul
 The MOTM-320 LFO, I have(2) First one assembled with
standard kit parts.
The second MOTM-320 I replaced all Resistors with
Vishay RN55e B 0.1% 25ppm you known these. sampled.
First one Standard kit has a Frequency output 34.4Hz
with no inputs only  sine out jack. measured..
The Second (MOTM-320 .1%) with no inputs, My Frequency
counter reads 20.5Hz in the sine output jack.
The Spec sheet reads Frequency range ( 0.002Hz to
1400Hz (typical) is this with no inputs only rate Knob
adjust 0 to max. or input 1V/Oct -5V to +5V ...
The 1V/OCT input what is the -5V to +5V frequency min.
to max. your  Ref MOTM-320.
I have read the theory notes, Cap. C8-pps Rate change.
I don't want to change that value.
I just need to known if there's a Resistor Value that
has changed the standard factory settings. Frequecy
spec. what is the freq.
Thanks Paul.
Don
Do You Yahoo!?
http://mail.yahoo.com
