HELP! MOTM-800 Box Caps
1999-11-08 by Tkacs, Ken
Paul, are you online? Please help!
I'm home from work building my modules today. I'm halfway through the 800 EG
and I'm stuck on the "yellow box caps." The manual says they should be
marked "102" & "104" but mine are "1n0 J 63*" and "10n J 63*"
I can make a guess as to which is which, but I'd rather not. I've never seen
this type of cap before, nor is it mentioned in any of my books.
What's a fella to do?  :)
Thanks in advance!
Re: HELP! MOTM-800 Box Caps
1999-11-08 by The Old Crow
  I'm not Paul, but here is how these codes work:
  102 = 10 x 10^2  x 10^-12 = 1000 picofarads = 0.001 microfarads
  104 = 10 x 10^4 x 10^-12 = 100,000 picofarads = 0.1 microfarads
  1n0 = 1.0 "nanofarads" = 1 x 10^-9, = 1000 x 10^-12 = 0.001 microfarads
  10n = 10 nanofarads = 10 x 10^-9 = 0.01 microfarads
  100n = 100 nanofarads = 100 x 10^-9 = 0.1 microfarads
  Are you sure the one cap isn't a 100n  ?
  --Scott
1999-11-08 by Paul Schreiber
EG
 In addition, the J means 5% tolerance and the 63 means 63VDC rated.
Crow is right, 1n = .001uf, 10n = 0.01uf, 100n = 0.1uf.
The nf is strictly a European thing.
remembers mmf (pre-picofarad)
  We should find an excuse to put a 1F cap in a MOTM.  1F 5.5WVDC caps are
about $6 ea. these days..heh heh
  Make an LFO of 0.0000000000000000000000000000001Hz or something
  --Crow
1999-11-09 by The Old Crow
On Mon, 8 Nov 1999, J. Larry Hendry wrote:
> > From: The Old Crow <oldcrow@...>
> are
> Either that or up the voltage and use them for power failure ride through
> on the supply lines.
  Well, that is what they're actually for. ^^  They're nonvolatile RAM
backup capacitors that keep data in CMOS static RAM intact for up to
several weeks in the absence of system power.
  --Crow
1999-11-09 by J. Larry Hendry
> Paul S.
One that small would be a miniature mf ?
<snicker> :)
LH
are
Larry (feeling particularly Stoogy today) Hendry
