RE: [motm] Real Ring Modulator
2005-03-09 by rdrake
i've got one, and like it quite a bit. it sounds like--a ring modulator, very similar to the multipliers usually used for this effect, but... i hesitate to say "warmer", since that's so overused & underspecific, but there i said it. more organic? different in a good way, at least to my ears. i believe it does attenuate the signal(s) a bit... because of that and for versitility, you might want to add buffers w/ level controls on both ins and out (a couple of ken's 04 mixers would do it, if you don't want to wire 'em yourself). but i have mine unadorned in an Altoids tin w/ 1/8" jacks, use it all the time. i'll have it at AHMW if you're in the area. bbob
>Message: 1 > Date: Tue, 8 Mar 2005 20:00:19 -0800 (PST) > From: Don Ojeman <dfojeman@...> >Subject: Real Ring Modulator > >Does any one have this unit from CGS.synth passive >module? I am courious what it sound like. >Will it add more Fx? >DIY project.
