Re: ChaosFactory: quesstion
1999-11-05 by hodad1@xxxxxxxxxx.xxx
now here's something i was wondering about: Could you control a chaoscillator almost like a bandpass filter-- i.e., define a narrow (or not so narrow) band over which it could vary? & then make the bandwidth & band freq voltage controllable (separately)? Is this making sense? I'm thinking that being able to shift the range of the chaos in midstream would allow you to have two (or more) different "playing techniques" for your "instrument" (e.g. use one setting for staccato notes & one for sustained notes.) So am I on or off my rocker here? tomr
1999-11-05 by Paul Schreiber
See my original post. That is what I said: each PIC has a CV input. The CV input determines just how chaotic it behaves, Paul 'Chaos' Schreiber -----Original Message----- From: hodad1@... <hodad1@...> To: motm@onelist.com <motm@onelist.com> Date: Friday, November 05, 1999 5:51 PM
Subject: Re: [motm] ChaosFactory: quesstion >From: hodad1@... > > > >now here's something i was wondering about: >Could you control a chaoscillator almost like a bandpass filter-- >i.e., define a narrow (or not so narrow) band over which it could vary? >& then make the bandwidth & band freq voltage controllable (separately)? >Is this making sense? >I'm thinking that being able to shift the range of the chaos in midstream >would >allow you to have two (or more) different "playing techniques" for your >"instrument" >(e.g. use one setting for staccato notes & one for sustained notes.) > >So am I on or off my rocker here? > >tomr > >>
1999-11-06 by JWBarlow@xxx.xxx
In a message dated 11/5/99 4:54:44 PM, synth1@... writes: >That is what I said: each PIC has a CV input. The CV input determines >just how chaotic it behaves, Stupid question: would this have something like a 1v/oct input? The reason I ask is if one is indexing through a number of "standard" musical phrases (or referents -- very postmodern!), and they are all in one key (say C), and the only means of transposing is to increase the voltage at the chaos input, then it seems that one would almost never perceive these phrases since they would often not be in the same key. And this comes from a (never in tune) guitar payer! JB
1999-11-06 by Paul Schreiber
No. My feeling was you do not "play" the chaos module. Rather, you place limits on the probability of the possible output. Paul S. -----Original Message----- From: JWBarlow@... <JWBarlow@...> To: motm@onelist.com <motm@onelist.com> Date: Friday, November 05, 1999 9:45 PM Subject: Re: [motm] ChaosFactory: quesstion >From: JWBarlow@... > > >In a message dated 11/5/99 4:54:44 PM, synth1@... writes: > >>That is what I said: each PIC has a CV input. The CV input determines >>just how chaotic it behaves, > >Stupid question: would this have something like a 1v/oct input? The reason I >ask is if one is indexing through a number of "standard" musical phrases (or >referents -- very postmodern!), and they are all in one key (say C), and the >only means of transposing is to increase the voltage at the chaos input, then >it seems that one would almost never perceive these phrases since they would
>often not be in the same key. > >And this comes from a (never in tune) guitar payer! >JB > >>
1999-11-07 by JWBarlow@xxx.xxx
I was thinking about this idea a bit over the past couple of days (in between reading speed typist Hendry's several different perfect solutions to his Magic Bus concept!) and I thought how I might like a module to behave in a similar regard to what motivated my previous question (below). I'd like to see a VCO that also had a chaotic input. What I mean is with 0V at the CHAOS input it would track like a good VCO, but as the voltage increased at that same input, the output would be increasingly indeterminate (either chaotic or nonlinear in some other way). I use a similar approach to my guitar playing when playing rather loud to produce two very different types of feedback. One kind is the more common controlled style (a harmonic style developed by Buddy Guy, Townshend, Hendrix, etc.) which involves inducing the string (or strings) to resonate via the speaker's output. The other type involves holding the guitar pickups about 12" from the speaker (again at very high SPL) which causes the pickup itself to resonate (I think most PUs have a resonant frequency of around 8KHz), producing a squealing sound -- BTW, I've come to believe this is destructive to the guitar's PUs (not to mention ears), so do this at your own risk. It is easy to use modules to mimic either type of behavior (harmonic or chaotic) but it requires a number of modules which are usually better suited for other purposes. So yesterday I tried a bit of an experiment to induce chaotic behavior with a small number of MOTM modules. About 18 months ago someone posted to the DIY list that he'd done some work on chaotic (Chua) oscillators, and mentioned that chaotic behavior could be coaxed from a standard VCO by plugging an output into an FM input of the same oscillator, though it may need to be amplified first. So I took an output from a MOTM 300 and routed it through a MOTM 110 VCA and then back into the 300 FM input. I used the pressure output from my Serge Touch Keyboard to control the gain of the VCA (the GAIN knob on the 110 was at full). While I found this patch did a little of what I'd expected, I needed to add another 300 as a basic VCO (for tracking the keyboard), and have the chaos VCO sync to the second VCO, since it didn't seem to track very well. I also thought that the effect might be more pronounced if my CV source went from 0-10V (the Serge only goes to 5V). If the effect had been more pronounced, I had intended to try using a VCF in the feedback loop, but that would be premature at this time. I'm wondering if anyone has any experience with patches like this, or if anyone else is interested in this type of behavior from what would otherwise be a standard module? John (Ziegfried) Barlow In a message dated 11/5/99 9:24:59 PM, synth1@... writes:
>No. My feeling was you do not "play" the chaos module. Rather, you >place limits on the probability of the possible output. >>From: JWBarlow@... >>In a message dated 11/5/99 4:54:44 PM, synth1@... writes: >>>That is what I said: each PIC has a CV input. The CV input determines >>>just how chaotic it behaves, >>Stupid question: would this have something like a 1v/oct input? The reason >I >>ask is if one is indexing through a number of "standard" musical phrases >(or >>referents -- very postmodern!), and they are all in one key (say C), and >the >>only means of transposing is to increase the voltage at the chaos input, >then >>it seems that one would almost never perceive these phrases since they >would >>often not be in the same key. >>And this comes from a (never in tune) guitar payer! >>JB
1999-11-07 by DAVEVOSH@xxx.xxx
In a message dated 99-11-07 16:39:16 EST, you write:
<< I'm wondering if anyone has any experience with
from what would otherwise be a standard module? >>
john,
3 vco`s in a closed loop produce a nice, noisy effect.
vco ----------------> out
vco --| |
vco----| |
( fm input or normal 1v/oct input )
all 3 vco`s track the same controller voltage. try soft syncing them also.
relative tuning of the vco`s is crucial.
best,
dave1999-11-08 by hodad1@xxxxxxxxxx.xxx
so can anyone suggest a good place to read about chaoscillator type stuff that's for the math impaired? I'd like to have a better grasp of all this but mathematical formulae might as well be written in Elvish as far as I'm concerned. tomr
1999-11-08 by Christopher Jeris
> so can anyone suggest a good place to read about chaoscillator type stuff > that's for the math impaired? I'd like to have a better grasp of all this > but mathematical formulae might as well be written in Elvish as far as > I'm concerned. WHOA ... IT'S A HUNKA HUNKA BURNIN FOURIER ANALYSIS ... oh, sorry, you said "Elvish" :) Chris
