Module Selection
Module Selection
2005-02-16 by Wood
Hey guys, I am mostly quiet on the list as I don't know much about all this yet, but I love to read
all the stuff. I have finally found some time today for messing
around with my modules and everything seems to work ok. I have built the 420 Filter, 800 EG, and 190
VCA so far. The 800 seems to need a pretty slow frequency trigger/gate to really have much affect on
the Filter or the VCA. But I ran my 909 through them with my MC202 providing the gate and it was
pretty cool sounding. Not much luck using the 909 as trigger though. Anyway if anyone has any
patching or setup advice I would love to hear it, as I am new to this and I am sure I don't know what
I am doing. Also, what do you all think is a good next piece? I was thinking the 300 VCO would be the
logical choice but I am open to suggestion in this regard as well, maybe I should get another 800 or
another filter before I get the 300? Thanks in advance for any helpful words you may have.
Eric Wood
Wisconsin
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.8 - Release Date: 2/14/2005
Re: [motm] Module Selection
2005-02-17 by Mike Estee
That's enough for some serious kick :) Put the filter into self res, and
drop the frequency low. Now it's a sinewave oscillator, which we're going
to change the pitch on using an EG. Then use the 909 (I use an 808) to
trigger the gate on the 800. Set the attack and decay to nothing, the
sustain to around mid, and the release to taste.
With no sustain and release you will only here sound for the length of the
gate trigger. Which is almost nothing ;)
The positive output from the 800 goes into FM1 on the 420, adjust FM1 to
taste. By playing with the attack, hold, and release times on the 800 and
the FM1 on the filter you can get an amazing array of kicks, everything
from heavy hip-hop type booms to no-hope-for-mankinds-future psytrance
death kicks. Play around. Get a feel for how different parameters change
different aspects of the sound.
Two 300s, not one. You'll thank me later. 300's have the sync jack. Then
the 440, which (I believe) is Paul's best filter. It's the one I use the
most anyway, I have 2 of those. Oh, and a 910, which I use in every patch
--mikes
Re: Module Selection
2005-02-17 by cormallen
> Then the 440, which (I believe) is Paul's best filter. It's the one I
> use the most anyway, I have 2 of those. Oh, and a 910, which I use in
> every patch ;)
> --mikes
I'll second both of those thoughts. Two oscillators are *so* much
more fun that one (and the 300 is a lot more versatile than the 310 -
if I was buying my rig all over again, I'd have four 300s instead of
two 300s and two 310s).
The 440 is also my favourite filter so far.
Harry
p.s. You can never have too many VCAs...
