switchcraft jacks?
switchcraft jacks?
2005-02-16 by Ben Vehorn
I'm thinking about making my own mult/converter panel, similar to the
MOTM 940 but in 19" format.
What is the Switchcraft model number for the 1/8" jacks on the MOTM
940? I really like these and would like to use the same type.
Thanks.
---Ben
Re: [motm] switchcraft jacks?
2005-02-16 by Paul Schreiber
142A
But, note the '940 uses a 'trick', the jack locations for these are end-milled
down 0.060 else the threads won't be long enough. You will want to use a
standard 0.062 thick panel (unless you want to end-mill).
To: <motm@yahoogroups.com>
Sent: Tuesday, February 15, 2005 6:03 PM
Subject: [motm] switchcraft jacks?
> Thanks.
> ---Ben
