Anyone have experience with the Synthesizers.com Q118 module?
2005-02-14 by chad_kettering
Index last updated: 2026-03-31 01:40 UTC
2005-02-14 by David Moylan
>Hello,
>I am building a MOTM system for not only analogue synthesis but also
>to process other synths and acoustic sources. The Synthesizers.com
>module looks like a great idea to generate a gate signal from an audio
>source to control an EG for a MOTM filter. Is it effective?
>Or should I use a Midi signal to trigger a gate generated by a Midi to
>CV converter?
>The midi triggering concerns me a little due to possible latency issues.
>Thanks
>Yahoo! Groups Links
2005-02-14 by tontaub
> > -----Original Message-----What's the angle you want to have between the two cabinets?
> > From: Michael Zacherl <egroups@...>
> > So you join the wing/s and the existing (main?) cabinet?
> No, they will just sit side by side. But, the cabinet shape
> will be such that they "nest," The angle of use is predetermined
> as the cabinet side will not be straight.
> > AFAIK the System 700 cabinets were just stacked and stood nextSmall like 12U wide or so?
> > to each other.
> You are correct. Here are several photos of a system 700 for about
> 3 years ago at AHMW.
> http://www.wiseguysynth.com/larry/ahmw2002/ahmw2002.htm
> > How will you transport your system?
> The same way I do now: carefully and infrequently. But, the wing
> cabinets will be the smallest. So, the moving difficulty is not
> worsened. The big 2 row slant cabinet is the worst to move today.
> This is not a gigging tool for me. My cabinets would certainly be
> different for that.
> > I'm looking forward to see your documentary on your site ;-):-) Michael.
> OK, it will be there, eventually.
2005-02-15 by tontaub
> > From: Michael Zacherl <egroups@...>Yeah, mockups are a good thing! A friend gave me an old vat (?) made
> I measured / calculated 42 degrees as what I wanted. I am going to
> build a mock up with cheap chip board at 45 degrees and see how I
> like it.
> The bottom cabinets will have all the angles. On top of thoseHow many single row top cabinets you have got meanwhile on your main
> (same width) will sit 12U high, 19" wide rack cabinets. In those
> cabinets I will be able to mix MOTM modules on rack rails with rack
> mount gear like my Kenton pro-2000 and more. I will not know the
> exact ability of the bottom cabinets for module space until I get
> the prototype built. Some adjustment to my plans is anticipated as
> I work through details.
> Re gigging cabinets:hehe - but with a system big like your's lack of some patching talent
> Sure. Something about the size of the dot com portable cabinets.
> But, gigging and modular do not mix for me. I'll leave that to
> those with significantly more patching talent.
2005-02-15 by J. Larry Hendry
> -----Original Message-----I don't know how else to do it. There is a compound angle on the lower
> From: tontaub [mailto:egroups@...]
> How many single row top cabinets you have got meanwhile on your maincabinet? Two or three? 2 row slanted + Magic Bus is a bit lower than 10U I
> seriously - I really do admire people like Robert Rich and all others whomanage to _play_ a modular system live in a way that it's more than just
2005-02-15 by charlesosthelder
>audio
> Hello,
> source to control an EG for a MOTM filter. Is it effective?to
> CV converter?issues.
> Thanks
