Index last updated: 2026-04-03 18:09 UTC
For Sale MOTM modules - Was panel dial indicators
1999-11-05 by J. Larry Hendry
> The older, original panels were all screened manually.
> The newer ones are on an automated machine, this
> has 4X finer resolution and hence allows for the
> in-between ticks.
> As the older panels run out, I will re-edit the dials
> for newer ticks. The older panels are then "vintage"
> and their value doubles.
Since MOTM has no blue book association, I consider Paul the only reliable
source of estimated value of these "vintage modules."  Therefore, based on
his assessment as indicated below, my MOTM-100 and MOTM-110 are now for
sale for two times what Paul sells them for new.  Clearly, the MOTM-100 is
now out of production and you will have to settle for the newer (and
slightly less vintage) MOTM-101.
Don't compromise your dedication to using vintage gear.  Buy mine today and
save yourself the embarrassment of having to explain why you don't have any
of the originals at your next gig.
For those of you who are anal retentive about construction and think yours
might be better than mine, I will gladly exchange faceplates only.  Of
course, I do expect to be compensated with enough money to buy another MOTM
module of the same model number since you are getting such a good deal on
the two-for-one exchange.
Better hurry on this one.  These one-of-a-kind vintage panels will not last
long.  If I don't secure a buyer tonight, these are hitting e-bay tomorrow.
Larry (I'm serious about this swamp land thing)  Hendry
