MOTM-810 VC ADSR
MOTM-810 VC ADSR
2005-02-12 by Paul Schreiber
JH battled the flu this week and finished his simulations for the MOTM-810 a VC
ADSR with typical MOTM over-the-top specs. Kit builders will delight at the
nearly 90 resistors, 18 transistors, 16 diodes, 15 op amps AND a blinky LED.
This is how the controls/ins/outs are set *currently*, and of course open to
wide (but civil) debate. No cost yet: the parts are cheap (in fact no single
part on the pcb is over 22 cents) but the *labor* on the PH side will be
extensive. I will say this: if I get 80 modules pre-ordered (and DO NOT SEND ME
THIS NOW!) I will get them pre-inserted like the '480s. The resistors, that is.
I have *no idea* on the final cost, but it will be over $149 but less than $249.
Remember, you are paying mainly for the front panel controls (see below) and the
labor in just amassing all these parts. But when has MOTM disappointed in our
over-the-top-ness :)
2U wide
CV inputs
A, D, S and R CVs (-5V to +5V range. A positive voltage ADDS to the panel's
setting, a negative voltage subtracts the setting)
Velocity CV (set up for 0 to +5V)
Outputs
Dynamic EG Out: the VCA'd version of the positive envelope. This is not for
passing audio through, it's so that the Velocity out of the MOTM-650 can scale
the overall amplitude of the envelope.
Positive and Negative EG Out. Times are <1ms to over 24sec for A, D and R.
Gate IN
MODE switch: Normal/Burst/Cycle. In Cycle, the EG internally retriggers at the
end of the Release and re-Attacks. This happens no matter what GATE is doing, so
it's like the Serge DSG (a wacky LFO thingy). In BURST, the EG CYCLEs as long as
GATE is high, then it releases and stops.
Now, the astute folks will see a lack of input attenuators of the 4 CV ins.
Why...no fit! But I can add 2 general uncommitted attenuators that you can patch
in if you need them. Also keeps the price down, because if you want 8 pots, 9
jacks, a switch and a LED you are in the $300 module range....so be careful what
you wish for :)
Comments?
Re: [motm] MOTM-810 VC ADSR
2005-02-12 by Josue Arias
I think a cycle output and trigger input would be useful, at least the
cycle out for firing another module at the end of the envelope..
Best Regards,
Josue.
On Fri, 11 Feb 2005 18:43:20 -0600, Paul Schreiber <synth1@airmail.net> wrote:
> 2U wide
> CV inputs
> Outputs
> Gate IN
> you wish for :)
> Comments?
> Paul S.
2005-02-12 by john mahoney
I was gonna ask for a trigger input.
An end-of-cycle output is a great idea!
john
To: "Paul Schreiber" <synth1@...>
Cc: <motm@yahoogroups.com>
Sent: Friday, February 11, 2005 7:59 PM
Subject: Re: [motm] MOTM-810 VC ADSR
Best Regards,
Josue.
RE: [motm] MOTM-810 VC ADSR
2005-02-12 by John Loffink
I will buy at least two of these.  This module will greatly help with
dynamic articulation of sounds.  I like the feature set including the
Velocity VC level, with a few suggestions...
I'd like to have simultaneous linear and logarithmic outputs - same FP real
estate and less cost than a lin/log switch or knob.
Two freely patchable attenuators works.  Another option is the Evos ADSR
type VC selector which cycles through all combinations of the four CV
parameters.  This requires a knob and 4 LEDs though.
http://www.wavemakers-synth.com/evos/EVOS_04.jpg
You might not need both burst and cycle switch settings.  If you put a
pullup on the gate input, when you switch to burst/cycle without a gate
input you get continuous (cycle), if you have a gate input it functions as
burst.
John Loffink
> -----Original Message-----
> From: Josue Arias [mailto:josue.arias@...]
> Sent: Friday, February 11, 2005 7:00 PM
> To: Paul Schreiber
> Cc: motm@yahoogroups.com
> Best Regards,
> Josue.
> On Fri, 11 Feb 2005 18:43:20 -0600, Paul Schreiber <synth1@...>
> 810 a VC
> the
> LED.
> open to
> single
> SEND ME
> that is.
> than $249.
> and the
> in our
> > 2U wide
> > CV inputs
> panel's
> > Outputs
> for
> scale
> R.
> > Gate IN
> at the
> doing, so
> long as
> ins.
> can patch
> pots, 9
> careful what
> > you wish for :)
> > Comments?
> > Paul S.
> > Yahoo! Groups Links
2005-02-12 by Mike Estee
On Fri, 11 Feb 2005, Paul Schreiber wrote:
> Comments?
Damn. I was just thinking yesterday evening I wanted a CV controlled ADSR.
Can't wait for it to ship!
--mikes
2005-02-12 by The Old Crow
I have an EOC output on my filter ADSR design, but problems obtaining
the desired dual-concentric pots has kept me from completing the thing for
2 years now.  Besides, JH's circuit is going to be better anyway. ;)
Crow
> john
2005-02-12 by Jeff Laity
I like the idea of the two general use attenuators. I don't think I
would be modulating more than two parameters simultaneously. This
sounds like a very exciting module.
> CV ins.
> you can patch
> pots, 9
> careful what
>  you wish for :)
>  Comments?
