Index last updated: 2026-03-31 13:59 UTC
Re: Update (DX7 on a chip)
2005-02-11 by Eric Frampton
Ivan Wrote:
> I would think that future digital MOTM products should be unique;
> there are already DX-7's in a box, for example (I've got a a couple of
> them inside my Kenton PlugStation).
> Personally I'm still looking forward to the MOTM Bi-Phase. There
> isn't anything quite like that currently on the market.
I agree with both of these things, though if I know Paul S's like I
think I do, his "DX-7 on a chip" reference probably was meant more as
an "imagine what we can do" than "I'd actually like to put a DX7 on a
chip".
I've got an 816 rack and a line on 2 more if anybody wants 'em. We
don't need to re-invent -that- wheel.
And I too am looking forward to a VC Bi-Phase!
e
2005-02-11 by paulhaneberg
I used to have a TX816, but programjming it was a bitch. I probably
would have kept it if it would have had knobs. I even toyed with
the idea of building a huge panel with knobs to control all the
parameters.
What I'm suggesting is not a DX7 on a chip. What I'm suggesting is
a single voice DX7 spread across 8 or 10 modules, with the ability
to patch into any point in the algorithm with a control or audio
frequency signal, and the ability to patch (as sort of an insert) in
filters and other processors into the chain. Imagine running that
hard, sterile DX7 sound through a 440 or a 420, not just at the
output, but at any point in the process. Imagine being able to lag
process the frequency control of some operators, but not others in
the same patch.
Now maybe the same thing would be better realized by building fully
analog oscillators capable of through zero FM, and DX7 style
envelope generators. But since the DX7 voices are DCOs and DEGs
anyway, using a digital implementation would seem to be the way to
go.
Re: [motm] Re: Update (DX7 on a chip)
2005-02-11 by The Old Crow
I did this, and I even did it before the Jellinghaus device was offered.
I sold when I was done with college, though. No idea what happened to it.
I only have one of the spare operator panels left:
http://www.oldcrows.net/~oldcrow/synth/crow/DXPatchMaster.jpg
http://www.oldcrows.net/~oldcrow/synth/crow/DXPatchMaster2.jpg
This thing was built into a "DJ desk" that was rescued from the
scrapheap. I wish I still had it just for the sentimental value, but as a
poor college student in 1986 I needed the money. I have to use a measly
DX-1 as a programmer now. ;)
Crow
On Fri, 11 Feb 2005, paulhaneberg wrote:
> I used to have a TX816, but programming it was a bitch. I probably
> parameters.
2005-02-12 by Eric Frampton
Gotcha. Actually I was talking about Schreiber's original post that
just said "DX7 on a chip". Sorry for the confusion. Though I like this
idea a lot, too.
816's plus Galaxy+ on a PM9600,
Eric
2005-02-12 by Jeff Laity
What sounds interesting to me is modular FM. The DX-7 algorithm could
be replaced by a patchbay of jacks. This way, operator 4 could be
processed through a Wavewarper before modulating operator 1. Each input
would have its own pitch control and CV (with LED frequency display),
as well as level CV.
Hey, I just designed a $600 module. Perhaps I should back off a bit. I
actually like the Additive module idea better, since much of this FM
and AM can already be done on MOTM with 300s and Wavewarpers.
> of
> chip".
> e
2005-02-13 by Overand
I've been hearing a lot of talk about people wanting modular DX-7 clones.
This doesn't seem to make a whole lot of sense to me. When you're in
the analog world, you can patch together a fairly complex FM patch using
analog oscillators, but anything past a few 'operators' worth of
emulating a digital FM synth will result in a lot of mush. VCOs just
seem to act flaky when you push them like this. Maybe this isn't the
case with beasts like the MOTM-300, but as far as I know, trying to do
analog FM past the level of complexity you get with maybe 3 chained VCOs
doesn't work predictably like digital FM does. So, if my understanding
of the limits of using analog data to accomplish FM is correct, you'd
need to be sending *digital* data from operator module to operator
module. Sure, you could send digital data out over the same patch cords
you use, the cables don't care if they're carrying S/PDIF or +-5 Volts
analog audio. But this means you can't patch through your other analog
modules.
Perhaps this would work using digital oscillators sending out and taking
in analog signal, but this means that each module is going to need a set
of DACs and ADCs, and it's going to need to figure out exactly what the
signal coming in is, for example convert the audio-version of the sine
wave it 'hears' to a mathematically perfect sine wave? Maybe this
wouldn't be neccesary, but it does seem that it would be to me.
As far as I can tell, getting 'real' DX-7 emulation via modules would
require digital modules with digital inputs and outputs, which would
preclude any passing of operators through things like the wavewarper.
-Geoff
> input would have its own pitch control and CV (with LED frequency
> display), as well as level CV.
> couple of
> chip".
> e
2005-02-13 by Jeff Laity
Right – Paul is talking about making a digital module, not analog. My
design would require a lot of AD/DA conversions, though, so it may not
be practical. A more inexpensive system would be similar to Yamaha FM
synths which select an algorithm from a list.
> require digital modules with digital inputs and outputs...
The point I was trying to make, and one I think that everyone agrees
on, is that new modules should not simply duplicate easily-available
technology. There's not really a point of DX-7 in a module, since
they're easy to find, but there might be something to modular FM
– though modular additive sounds more interesting to me. Or non-modular
even, if Synthtech ever strayed from the MOTM modular and moved into a
traditional synth or module.
